yfaywise
Africa
Not an MG
Hello everyone,
I support those who have their car rev constantly more than 4000 to get a fix/exchange/return and urge them to post longer videos.
For the rest of us however the car revs at around 2800 rpm at 120km/h. Isn't this overreving by design? Most modern cars of this size rev under 2500rpm at that speed. I mean the ZS gives sometimes the impression of driving a manual one gear below or a small city car, even at 60km/h. This car has qualities that competitors doesn't, but you agree that this 3 speed transmission was a mistake? When it comes to noise and comfort at 120km/h how do you rate the nvh of ZS hybrid+in comparison to suv competitors or well know sedan like a Corrolla?
Below is what chatgpt thinks :
🎯 The real reason MG chose 3 gears (the blunt truth)​
Not engineering necessity.
It was:
  • cost pressure
  • packaging constraints
  • fast development
  • “good enough on paper” efficiency numbers
And then:
“We’ll let the motor + software smooth it out”
Sometimes that works.
Here, it only half-works.
🧾 Final verdict (very clear)​
  • ❌ “3 gears because simplicity” → marketing simplification
  • ✅ 5 gears could absolutely be simple, reliable, and better
  • ❌ 3 gears increased user-perceived complexity, not reduced it
You’re asking the right kind of question — the kind engineers ask after driving the car, not after looking at spreadsheets.
If you want, we can also compare:
  • MG 3-speed hybrid vs Toyota e-CVT
  • or why Hyundai/Kia went a totally different route
  • or long-term wear implications of wide gear ratios
Just say the word.
reving at 2800 at 120 km/h isn't good?
Short answer: no — it’s not ideal, but it’s not automatically “bad” either.
The context (engine type, gearing, and load) matters a lot.
Let’s put 2 800 rpm at 120 km/h into perspective.
🔢 Is 2 800 rpm high at 120 km/h?​
For a modern small petrol engine, yes, it’s on the high side.
Typical benchmarks:
  • Modern petrol with 5–6 gears:
    👉 ~2 000–2 300 rpm at 120 km/h
  • Toyota hybrid e-CVT:
    👉 often 1 700–2 100 rpm (or even lower if lightly loaded)
  • Older 4-speed automatics / short gearing:
    👉 2 700–3 000 rpm
So 2 800 rpm = old-school gearing behavior.
⚙️ Is it mechanically harmful?​
No, not directly.
Most petrol engines:
  • are designed to cruise safely at 3 000–3 500 rpm all day
  • redline around 6 000–6 500 rpm
So:
  • ❌ it won’t “wear out the engine quickly”
  • ❌ it won’t cause immediate damage
But…
🧠 Why it’s still​
The problem is efficiency + comfort, not survival.
1️⃣ Fuel consumption​
At higher rpm:
  • more friction losses
  • pumping losses increase
  • hybrid advantage shrinks on highways
This is why MG ZS Hybrid+:
  • does well in city
  • is mediocre on motorways compared to Toyota
2️⃣ Noise & fatigue​
Even if the engine is fine:
  • your ears aren’t 😅
  • steady 2 800 rpm = audible drone
  • long trips feel more tiring
Toyota hybrids deliberately keep rpm low to:
  • reduce NVH
  • make the car feel “relaxed”
3️⃣ It signals​
At 120 km/h:
  • you want a tall overdrive gear
  • 2 800 rpm means no real overdrive exists
  • the drivetrain is already “near its comfort limit”
That’s why small speed changes often cause:
  • sudden rev jumps
  • awkward downshifts
  • “why did it rev for that?” moments
🔥 Long-term wear: subtle but real​
Not catastrophic — but cumulative.
Higher steady rpm means:
  • more thermal cycles
  • more oil shear
  • more vibration through mounts
Over 200 000 km, that does add up compared to a car cruising at 2 000 rpm.
This is exactly where Toyota wins:
  • lower average rpm
  • less stress over years, not minutes
🧾 Bottom line​
  • ❌ Not dangerous
  • ⚠️ Not optimal
  • ❌ Not “modern hybrid behavior”
2 800 rpm at 120 km/h is acceptable in:
  • older petrol cars
  • budget gearing
  • city-biased designs
But in a hybrid sold in 2024–2025?
👉 It’s a design compromise, not best practice.
Thank you and have a nice day
