ntompson
- Nov 25, 2021
- Location
- Hobart, Australia
- MG ZS EV
Update as of 27 December 2021: if you're having issues with ACC, check how your front number plate is installed; it could be blocking the radar - see post #17 below.
Original post:
Hi all,
First post from a happy new MG ZS EV owner. I'd love to hear about your experience with adaptive cruise control (ACC) to know if what I am experiencing is abnormal and could be an indication of a fault.
Among the many cool features I'm learning, I've been quite impressed with the ACC. It's handled busy stop / start traffic scenarios quite well (not always super smooth, but pretty good nonetheless).
Having said that, I've had a few cases where ACC suddenly decides to slow the car down for no obvious reason (no traffic ahead of me or coming towards me). One example is along a straight (wide) suburban main road when passing a parked car. Another example is a straight suburban road with a large concrete embankment quite close to the edge of the road (this one has happened on multiple passes of the same spot). Both are 50 km/h zones.
In these cases, ACC suddenly throttles back and then half a second later applies the brakes (which makes a bad sound). I'm not completely confident, but it sounds / feels like the braking is heaviest on the left hand side of the car (we drive on the left in Australia).
One observation is that this has only happened when the sun angle is relatively low creating a little glare looking through the windscreen (but not that much). I had assumed that ACC only uses the radar, but maybe it also uses the windscreen camera? The windscreen is clean.
So I'd appreciate the benefit of your experience: is this is a common occurrence for ACC in the MG ZS EV? Or is this unusual and I should assume that something is wrong, needing fixing? It's a rather unsettling experience and makes me nervous about what might happen at higher speeds.
Many thanks,
Nick
Original title: Unexpected braking when using adaptive cruise control (ACC)
Original post:
Hi all,
Many thanks,
Nick
