hi all, I have a 2021 ZS EV and in it's handbook it states that it can take up 27 hours on the charger for the battery to be fully rebalanced.
I find this strange, as I was of the opinion that the car would only try to balance the battery for up to about 10 hours, then if this was unsuccessful it would stop and then retry the next time it was asked to perform a balance.
It has been found that the balance cycle tends to be a shorter time scale, when the car is running on the original software, over the cars with the BMS update introduced on the 15th Jan 2021.
Generally a balance cycle on the original software would take anything from as little as 45 minutes to one and a half hours.
With the BMS update applied, regular cycle times can vary massively, but are never shorter than about two and a half to three hours minimum !.
It is thought, that this is a result of increasing the size of the buffer at the head of the battery on the BMS update.
My previous ZS EV Gen 1 had run on the original software firv12 months, then another 12 months on the latest software due to the BMS upgrade,
Balance cycles will only commence after 100% SOC has been reached.
With the BMS update applied.
When the SOC has hit 100% it will commence the balance cycle.
It starts by pulling around 750 Watts of power from a A/C supply, then it will reduce to 500 Watts.
It will continue to throttle back again closer to the end of the cycle, when it finally hits about 175 Watts.
Soon after this, the balance will complete and the car will automatically shut down the wall box or the Granny unit.
Balance cycle times are increased post BMS update, that is for sure !.
