J john1000uk Established Member 3rd Monthly Contributor Joined Sep 9, 2025 Messages 104 Reaction score 58 Points 42 Location TS116DU Driving MGS5 Friday at 8:29 PM #1 Does anyone know if the brake lights come on when you slow down using regen mode 2 or 3 ? to warn others. Especially with regen level 3.
5teep Prominent Member Runner-up #4 Joined Jun 29, 2021 Messages 1,872 Reaction score 1,886 Points 648 Location Cruising Driving MGS5 Friday at 8:36 PM #2 Should do yes, they had to do a software update to make the original MG5s do it. The only way to be sure is to have someone follow you and check.
Ian Key Distinguished Member Runner-up #2 Joined Sep 28, 2022 Messages 5,466 Reaction score 9,880 Points 2,660 Location Derby UK Driving MGS5 Saturday at 5:56 AM #3 If you look at the power metre in the driver's display when it gets to -7ish the brake lights should come on. That's what happens on the MG4 so I expect the same on the MGS5 although I haven't personally checked.
J john1000uk Established Member 3rd Monthly Contributor Joined Sep 9, 2025 Messages 104 Reaction score 58 Points 42 Location TS116DU Driving MGS5 Saturday at 9:30 AM #4 Thanks, will have a look when driving at night.
Alb Moderator Joined May 11, 2021 Messages 5,154 Solutions 6 Reaction score 6,694 Points 2,077 Location Gloucestershire driving an MGS5 LR Trophy Saturday at 10:10 AM #5 It's usually easy to tell in the dark.
D daEV Novice Member Joined May 25, 2023 Messages 9 Reaction score 1 Points 0 Location Swansea Driving Not an MG Saturday at 10:37 AM #6 Its when regen hits -5% i believe
