psybernoid
Bridgend
MG4 (2022-2025)
Does anyone have a recommendation for a good wireless Carplay dongle?
I've ordered and subsequently returned quite a few from Amazon. Including Carlinkit, Ottocast and more generic models. They all appear to use broadly the same hardware/firmware.
I have an iPhone Pro Max 17. 75% of the time, it'll connect up just fine. the other 25% of the time, it'll connect with a black screen. The GPS is terrible. Slow to update and often freezes. When using indicators at low speed when the camera kicks in, a previously working connection will most often come back to a black screen when the camera display closes and goes back to the Carplay view.
Music often skips when streaming (is fine when playing from downloaded onto the device)
With every dongle I've tried, I've tweaked multiple settings - from adjusting the wireless channels, setting audio/GPS/startup modes to type 1, 2, 3 etc. Nothing seems to solve it.
Car went in for service and software update yesterday. I was hoping that might resolve it. But nope.
When using the iPhone directly connected via USB cable, these problems don't exist.
Dongles need a delayed start up, but that won’t fix all the issues you’ve described.
Songs only paying smoothly when downloaded would indicate an issue with your phone’s connection/speed though, not necessarily the dongle. Same suspicion could be had with regards to bad gps signals.
I had a Quadlock dongle, which dropped out a lot after a while. Switched to Carlinkit 5.0 mini which has worked flawless until this morning. I am very suspicious of iOS 26 though, lots of things seem to have gone backwards with that update.
Indeed so. It's probably either iOS 26 and/or connectivity.
As I say, I've gone over pretty much every conceivable combination of startup delays, wifi channels etc. In fact, one of the carlinkit ones I tried - the 5.0 2air got its knickers in a twist when I selected one of the higher 5GHz channels (I forget which one) it just stopped broadcasting. And as there was no way to factory reset the thing, that too got returned.
As I said elsewhere, a Smart Dongle came with the car from the original owner. It works OK most of the time. I did get an Ottocast Play2Video Ultra 2.0 and it had more features but lagged a LOT. I did some research and found a fix for that issue. It was to configure the phone to connect using 5GHz instead of 2.4GHz. Apparently the difference is amazing and the lag almost disappears. The problem is that I have just upgraded from an iPhone 8 to the iPhone 11 and it does not have the ability to used 5Ghz in that mode.
Hence I have gone back to the Smart Dongle. It will be a few years before I upgrade my phone again. That will be when this model cannot update. I am really not interested in the camera functions as I have proper equipment to take photo's and any old phone will do what I need from such a small sensor.
I have one of those above in an MG HS, can confirm it works as expected most of the time. However it does take a minute or two to warm up which is annoying on short journeys.
I have exactly the same problem. I have yet to find a proper solution (apart from plugging in using the cable). I've had the same problem across multiple different iPhones/versions, so it isn't my phone. Sometime a new device works for a bit, then it goes flaky and no amount of settings, firmware updates, delays or other changes make a blind bit of difference - I've lost count of the number of times I've done factory resets and wiped my Phone's CarPlay/Wifi/Bluetooth networks to start again.
I'm awaiting the arrival of my 4th device to try to solve this. There won't be a 5th, I will probably give up after the 4th. If it somehow works well though, I will give details here.
I am curious as to why dongles need a delayed startup or is this just with IOS? I bought a XUDA dongle from Ali Express for $6.48 & installation was just plug it in, pair with the phone & that's it with Anfroid Auto. It only uses bluetooth to set up direct WiFi between the phone & car. It just starts automatically when I get in the car with the phone. AA was configured to start playing music automatically but I switched that off. No problems so far. No delays it just works.
In my case (which I think is similar to other cars) the car software takes a little while to get up and go, and some dongles stop trying to connect to the car before the car is ready. Setting the delay is telling the dongle to wait before trying to connect with the car, giving the car time to sort itself out.
I have been using wireless dongles for awhile and they worked most of the time with just a few connection issue now and again.
That said I recently got a new iphone with a USB-C instead. I have to say the wired connection now works without any issues. I have been using this for a few months.
    Votes: 1,072 77.8%
    Votes: 207 15.0%
    Votes: 100 7.3%
