constant speed control
Deleted member 19052
Have a nice evening,
on the French user manual (page 43 or 41 on the English manual for the symbol and 226 for the explanations), there are 2 symbols indicating that there is constant cruise control. Symbol identical to acc but without the car (on the dashboard).
but when intelligent driving is deactivated and no matter what I do on the pilot switch, nothing happens.
Can you help?
Thanks in advance
I think I found it.
I have carefully looked at the manual, it says that the vehicle must be driven at more than 25 mph to activate the constant cruise control.
I assume the driver assistance system must be disabled. It is not indicated.
I'll try.
In full ACC mode (which I constantly use), I can select cruise control and lane assist via the steering wheel button at speeds below 18mph and it will switch on, automatically selecting 18mph as the set speed. If thar makes sense!
I just did a test. without activating acc mode, of course there is nothing on the steering wheel button.
I turned on the ACC and didn't get constant cruise control.
I didn't know you could select lane keeping assist via the button. I disconnect it using the central screen shortcut.
I will try a speed lower than 18 mph.
thanks Keith S
I was trying to find it yesterday, but couldn't. There is active cruise control with lane keeping assist, active cruise control which always only follows the car in front, but other that there is only speed limiter (intelligent or constant), but no options for standard, constant speed control.
Completely agree, I can't find it, or it doesn't exist.
a bit like the on-board computer, where you should also be able to scroll (according to the manual), the media and the telephone which do not exist either.
thank you "aplesat", I understand better now, it saves them from publishing manuals for each model.
