DC Charging speed
MGPHOAWR
Belfast, UK
MG4 (2022-2025)
I'm not convinced my MG4 ER is hitting the speeds it should when rapid charging.
Today I plugged in at 35%. Ambient temperature 12°C but I had driven about 20 miles beforehand and I had on intelligent battery heating. Despite this the power never went above 67kW.
Surely they can't be normal? This was a 200kW charger and I've seen other cars getting well over 100kW on it.
Wasn't there a thing where a charger was listed as 200kW but on 800V architecture, and the MG4 is 400V so will only get 100kW max? I think I remember @Coulomb mentioning this once or twice.
Battery heating probably only comes on at or below 10°C.
It's possible that your main battery cells are not well balanced. Some cars spend a lot of time idle in transport and/or at showrooms, during which balance can drift off. If so, a few more balance cycles might improve the DC charging speed, as may increasing temperatures.
Could be lots of reasons as others have mentioned.
It could be that the site as a whole had its power throttled by the grid.
More likely it was your car that was limiting the power to protect the battery but you seem to have done a lot of the right things to avoid that.
Here is the charging curve from Fastned:
    Votes: 1,104 77.7%
    Votes: 214 15.1%
    Votes: 103 7.3%
