Detailed Look at the Dash, Driver Display and Steering Wheel Functions
Hi all, just purchased an MGS5 Trophy and hands up, I have been playing around with MG Pilot. I now have a very annoying and terse female shouting (well certainly a raised voice) that I am OVER THE SPEED LIMIT, whereas before I had a very soft voiced female telling me what the speed limit is.
Try as I might I cannot get rid of the loud female telling me off!
Any suggestions would be greatly appreciated.
Have a look in the built in sat nav app and the settings in there. I had to turn off speed alerts (or something similar) even though I wasn't using the built in sat nav
Edit: on Saturday nav, click menu button bottom left (3 bars), settings, warnings and turn off warn when speeding and that worked for me
Funnily enough I was just about to ask a whole load of questions about retaining settings from one drive to the next, specifically Driving Mode, the customised nature of Custom, One-Pedal Driving and last radio frequency (even which band is in use, let alone the station.)
I get it about MG Pilot, but all these other settings just seem to get forgotten, unless I am being dumb?
That was very useful but would have been even better if he had taken it at a slower pace.
You can change the playback speed in YouTube
Excellent advice, the female shouting at me has now left the building!! Thank you very much.
Check for passengers...
Ah, ChatGPT says it's about the brake pedal. I never use it, which is, I suppose, why I couldn't tell the difference. I wonder why there isn't an ⓘ?
I use One Pedal Driving, which works fine. I think the only time I press on the brake is when changing gear between frontwards and backwards and when in reverse (where OPD doesn't work.)
OPD is fine but you should use the brakes too just to keep them clean and free from rust. Just driving 'manually' every so often should be enough.
