Does a MG ZS Exclusive Mk1 Spare Wheel fit a MG S5 Trophy?
LouthMGZSEV
Louth
ZS EV
I am thinking of changing my MG ZS EV Exclusive mk1 for a MG S5 Trophy. As I have a spare wheel for my ZS EV I am wondering if it would fit a MG S5 Trophy, does anybody know?
The spare wheel you have, it is the MG space saver type ?.
If so, then yes it will on the car okay and it will JUST fit under the boot floor cover, on its highest setting.
Remember that the MGS5 has no spare wheel well formed into the body shell, unlike that in the ZS EV models.
The S5 Trophy wheels are 18" while the ZS EV space saver is only 16" so it is going to look a bit strange on the car though.
I think a 18" rim space saver set is a better fit tbh.
If you decide to go for the S5 you are going to see a HUGE difference from your ZS EV Mk1.
We have owned both models of the ZS EV and the S5 improvements are extremely welcomed.
You will not be disappointed.
Many Thanks for that.
It is an MG space saver. Just wanted to know if the bolt spacings were the same and it would clear the brake disc. As it's only for emergencies and I have has bad experiences with the Tyre sealer gunk. I will keep it out of my ZS and give it a try when I get the S5, if it looks unsafe/stupid I will sell it and buy an 18inch space saver.
I had a test drive in an S5 today and agree with you it feels a much more 'grown up' car, definitely getting a pre reg one.
I also sat in the S6 in the showroom and it seems another step on in quality, but too big for my garage, (and too expensive for me)!
Yeah - It is the same stud spacing as your current ZS EV so no problem there then.
The ZS EV used different wheel hubs from the previous ICE ZS models.
They decided to use the stronger heavy duty hubs from the older HS on the ZS EV instead.
Because the larger hubs from the HS model, had larger / stronger wheel bearings.
This helped accommodate the heavier load placed on the bearings, from the weight of the high voltage battery pack.
MG originally sold the space saver for the ZS ICE model, to the new owners of the ZS EV and soon discovered it would not fit.
So MG removed the kit from sale and quickly issued a new part number with a kit that would fit the car correctly !.
Other members of the forum have fitted the space saver from their ZS EVs and of course they fit okay.
However the car does look a bit strange when it’s installed given the wheel size difference.
I guess it really depends on just how far you intended to travel safely on one of these space savers ?.
Not too far would be my strong suggestion !.
Of course a “full sized” spare is the correct way to go really, but it is going to take up SO much space in the boot, for really long periods of time without use.
Let me know if A you get the S5 and how you find it over the ZS EV ?.
And then, how you view the car with the ZS EV space saver fitted ( if you decide to buy one ).
Well I have bought a new MG S5 Trophy in white.
I am very pleased with it, seems a sea change upgrade from my 2020 ZS Mk1 Exclusive and the wife's 2022 ZS Mk2 Trophy LR.
So much quieter, solid feeling and after the first 150 miles economy seems better around 3.7 m/kwh in cool wet weather compared to 3.3 m/kwh in the ZS. The interior is a nicer place to be and more room in the front and back.
I went to look at a £22.5k Demo model, but the garage matched my Car Wow quote for a new one at £23.5k, with a reasonable trade in for the old ZS EV Mk1.
I hope it is as reliable as the two ZSs which have completed nearly 100k miles without fault, needing only standard servicing, MOT and two front tyres each. Between them I calculate I have saved around £20k on fuel.
This is my fifth Chinese MG, having also done 100k miles in two petrol GSs which were also fault free except for two ABS sensors replaced under warranty.
I did have a sit in an S6 which looked and felt like a Limousine, but a bit rich for my budget and too big for my garage.
I said you would not be disappointed 👍🤣.
Like yourself, after owning both variants of the ZS EV the S5 is a big step up.
I did enjoy both of our ZS EV’s, but as you would expect from a ground up designed EV, it’s just better.
It’s does have its quirks ( just like other cars ) but hopefully 🤞 it will be as reliable.
These may sound a bit harsh but you could say, it’s the car the ZS EV should have been really.
Enjoy your “White Knight” 🤣.
Glad you are getting on ok with the S5. I'm liking my ZS EV LR, I have no complaints at all. It's totally reliable & fun to drive but I'm thinking I will definitely be trying the S5 soon & may upgrade to it if I like it. Have you done a review of your thoughts on the S5 yet?
I have already posted my thoughts on another thread, regarding the difference I have found between both models of the ZS EV and our MGS5.
I have not done a full review myself, as there are already many other members who have posted good reviews 👍.
I highly recommend that you DO take a test drive in the MGS5.
It is a big step change from the previous ZS EV models.
I will be extremely surprised if you don’t like or then buy one 👍.
Hi i just wondered if you tried the zs ev space saver wheel on the S5 - did it clear the brake calipers ok?
Yes the ZS EV space saver will fit the MGS5 with not problems, but just bare in mind that the ZS EV rim is a 16” and the rims on the S5 are 18” so it’s going to look a bit low on that corner.
I have my ZS EV genuine OEM space saver in the boot of our S5 and it just about fits under the boot cover, set on the highest setting.
The 18” space saver set up is going to be better option of course, but I bought this for £129.00 from the dealer for our Gen1 model when they first got released.
Not the perfect solution I guess, but anything is better than no spare wheel at all I guess.
I also carry a tin of Holts tyre 🛞 weld as well.
This Holts produce can be easily washed out of the tyre, unlike a lot of the gunk that comes supplied with a lot of cars now.
We had a puncture a few weeks ago and I discovered it while the car was parked on the drive.
Just inflated the tyre and set off straight away, to our local tyres shop.
No need for the space saver or the tyre weld on this occasion.
