ECU Module version spreadsheet
JodyS21
Milton Keynes
MG ZS EV
I'll update this top post as more data is provided.
In an attempt to figure out what the different versions of all the software do/cause, we are putting together a list of peoples car ecu versions.
If you have the OBD2 device (currently being looked at in another post) or OVMS, please post your details so that I can update the spreadsheet.
If you could provide as much information as you can think of to explain what version you think you have please, to hopefully enable us to work out what the differences are.
Please add any ideas etc that you have.
Spreadsheet link on dropbox here:
Date DevelopedDescriptionVersionNotes
23/08/2019? (600 P09)?0823600P09Singapore version?
25/11/2019 (600 R15)Original1125600R15
06/01/2020 (600 R17)12/20190106600R17
03/06/2020 (610 R28)7/20200603610R28Attempt to resolve long balance times
07/08/2020 (620 R32)?0807620R32 Australian version? (car production date 1/11/20)
16/10/2020 (620 R40)24/10/2020 ?1016620R40 Duff version. Need someone with this to check it
30/12/2020 (621 A01)15/1/20211230621A01The Fix :) now 450v
28/01/2020 (622 A00)0128622A00Australian version? (a car was updated 22/3/2021)
10/02/2021 (622 EU1)mid 2/20210210622EU1Possibly fixes some users reduced power issues?
Data regarding SoC & Voltages at full charge:
(SoC% seems to be related to the Max Cell Voltage)
I've created this graphic to show how the battery usage seems to really be:
Brilliant idea, It would be really handy if someone could upload the bad BMS version number from end of October. Also the new one from Jan :)
@Septian
Does your car have the graphics on the dash when you change mode/kers?
I'm hoping the answer is Yes, as that potentially tells us its the SCU eco version that does this....
@Septian
When I press the KERS switch the little 3 changes to a 2 or whatever, just the bottom bit changes
Damn it!!!!!!
FYI the graphics are on here:
That's blown by potential SCU ecu version being the cause of it!
The only other difference then I can see between the 3 cars data we have, is not a version, but rather that the car with the graphics was one that has had the comfort pack 2 update (re)installed at the dealer and probably not from the factory.....
Damn it!!!!!!
Oh wow, Mine certainly does nothing like that, I wish it did, that's pretty nice looking, haha.
Damn it!!!!!!
[/Q
QUOTE]
I got mine October 2020 and i assume it came from the factory with comfort 2 already installed.
@Alan5
Rather surprisingly, you have a new HVAC version that haven't seen before, bit strange as it is very similar to the others (REL_DC_BEV_C036) except yours is A instead of C (REL_DC_BEV_A036).
You have a "new" BMS version too (1125600R15)!
I was guessing as you had the car updated in Sep 2020 they'd have put the latest BMS on it then and therefore you'd have the 7/20 version, but I'm pretty sure you don't as @AbuG & @shikoku14 have the 7/20 version which is a different number. Could yours be the very original (pre 12/2019) never been updated BMS?
Can you do timed charges and or AC charge unlocked??
You also share a couple of other new versions with @Kithmo:
EVCC (AC charging ecu?)
DCDC (DC charging or is it 12V battery topup charging ecu?)
TC (Traction Control?)
Any idea what that could be about?
@Alan5
I think your right about the BMS being the original pre 12/2019 as it will only charge AC with doors locked not tried timed charging yet but I am guessing it won't work . When it goes in for the next service I am reluctant to have any new BMS update as I am quite happy with the BMS as it is , unless it affects the warranty if I don't have it updated ☹️ . Your other questions I will have a look at as I have only looked at what the app can do today but it all looks very promising 😊
It looks like (need some more data to validate).
Original BMS is version - 1125600R15
12/2019 BMS is version - 0106600R17
7/2020 BMS is version - 0603610R28
Guess 24/10/2020 BMS is version - 1016620R40
Need the 15/1/2021 BMS version.
Not too sure on this:
Original? - EVCC 1770099611 / DCDC F01R0A7242.
7/2020 To allow AC charge unlock & Allow more timed/smart chargers -
EVCC 1770124111 / DCDC F01R0A7355.
EVCC - Electrical Vehicle Charge Controller, this was updated to allow for upto a 10 hour delay to charging starting, more information here:
OBC - On Board Charger, this was updated to allow for unlocked AC charging, but this module doesn't appear to report in the list above. Link above provides more detail on this too.
DCDC - DC to DC Convertor, I believe converts the HVB voltage down to a smaller voltage for charging 12v battery (and probably a lot of other functions too)
TC - Traction Motor Control Module
Both of these were updated as part of the SA017(HVB Fuse update), see image below.
Fantastic info, thanks
Got 17 car version dumps now.
I think with some certainty we can say these are the (UK) BMS Versions:
Guessing 24/10/2020 BMS is version - 1016620R40 - Need someone with this to check it.
15/1/2021 BMS is version - 1230621A01
mid 2/2021 BMS is version 0210622EU1 !!!!!!!!!!!WTF!!!!!!!!!
EVCC We have 2 versions (Electrical Vehicle Charge Controller):
1770099611 - Think Previous version
1770124111 - Think is latest, Improves compatibility with smart and timed charging systems
DCDC (was updated as part of 6/8/20 SA017 to fix the main fuse blowing issue)
- seems (with 1 exception) to be linked to the EVCC version:
F01R0A7325 - Think is a very old version
F01R0A7242 - Is normally found with EVCC 1770099611
F01R0A7355 - (Normally goes with EVCC 1770124111)
TC (Traction Control - was updated as part of 6/8/20 SA017 to fix the main fuse blowing issue)
F01R0A7324 - Original version?
F01R0A7240 - ?
F01R0A7366 - Latest?
F01R0A7354 - Latest?
SCU versions:
194136858 C0807 - Older?
194136858 C0812 - Latest?
194136858 C0813 - Latest?
Has anyone successfully used an obd dongle using iOS and logged the data? I’d like to do mine.
F01R0A7240 - ?
SCU versions:
I'm wondering if those BMS numbers are build dates, if you take the American date format into effect. (Not sure about the year, but the dates kind of stack up)
EG
1230621A01 (30th December)
0210622EU1 (10th Feb)
0603610R28 (3rd June)
Etc.
