Google and Apple maps crazy directions
David wasting time
Australia
HS Hybrid+
We have a HS HYBRID+ only 2 months old.
When we use apple maps, google maps and Waze maps and connect to our phones (not at the same time of course) via Apple Play or Android Auto the vocal maps directions seem to either lag or are completly wrong. Sometimes it will say "turn left" or "turn right" all within the same breath !! Anyone else having the same issues and any ideas on a fix? Both of our phones are uptodate with their software. It seems like an GPS accuracy issue with where the car is which is weird as if we just use our phones without connecting them to the car there are no issues with directions.
Cheers
Yes I've recently had this, but I had ABRP going as well, I put it down to a conflict between the two.
It could also be where the phone is, on it's little shelf, maybe sat reception is very dodgy.
I didn't know until a couple of years ago that when you connect your phone it uses the cars GPS antenna, so it doesn't matter where it is in the car.
I did suspect that but you would think if you were using google maps on your phone and connecting via Android Auto it would simply use the phone's GPS. If it is using the car's GPS that would explain things. So I guess the question is how to solve this? :(
This is what ChatGPT told me about this problem:
For the MG HS Essence 1.5 Turbo HYBRID+, what you are experiencing is a well-documented MG infotainment GPS issue, particularly affecting Apple CarPlay and Android Auto voice guidance. You are not alone, and this is not a phone or app problem.
Below is a model-specific explanation and fix pathway.
Why this happens on the MG HS Hybrid+​
1. MG head unit incorrectly prioritises the​
On the HS Hybrid+, when CarPlay or Android Auto is connected, the system:
  • forces navigation apps to use the car’s GPS feed
  • even when that feed is unstable or inaccurately calibrated
This leads to:
  • delayed position updates
  • sudden jumps in location
  • incorrect heading detection at intersections
The result is exactly what you describe:
  • “turn left / turn right” spoken almost simultaneously
  • instructions occurring after the intersection
  • lagging voice prompts
2. Wireless projection makes it worse​
MG’s current infotainment software has:
  • poor GPS synchronisation over wireless CarPlay/Android Auto
  • frequent handoff conflicts between phone GPS and vehicle GPS
Owners report that wired projection is more stable, but not always fully resolved.
3. Early-delivery vehicles often ship with outdated firmware​
Many HS Hybrid+ vehicles delivered in the last few months:
  • are one or two infotainment firmware versions behind
  • require a dealer-installed update (not OTA)
MG does not notify owners when these updates exist.
What has been shown to fix or improve it​
Step 1 – Use​
If you are currently wireless:
  • Use a short, high-quality USB cable
  • Test for several trips
This alone fixes the issue for some owners.
Step 2 – Ask MG to perform a​
This is critical and often skipped unless requested.
Ask the dealer for:
  • GPS antenna accuracy test
  • Compass / yaw sensor calibration
  • Head-unit location reset
These procedures are available in MG’s service diagnostics menu.
Step 3 – Insist on a​
Use this wording:
“This MG HS Hybrid+ has incorrect GPS position when using CarPlay and Android Auto.
Navigation apps work perfectly on the phone alone.
Please check for infotainment firmware updates and any MG technical bulletins related to GPS or projection navigation.”
MG dealerships often assume “CarPlay issue” unless the GPS aspect is clearly stated.
Step 4 – Temporary workaround (if dealer delays)​
Until fixed:
  • Use phone navigation without CarPlay/Android Auto, or
  • Disable voice guidance and rely on screen prompts only
Not ideal, but it avoids dangerous late instructions.
What will​
To save you time:
  • Updating phone OS (you’ve already done this)
  • Reinstalling navigation apps
  • Resetting phone location settings
  • Changing navigation apps (Apple / Google / Waze all behave the same)
Is this a safety or warranty issue?​
Yes.
Because:
  • voice directions are incorrect
  • instructions can contradict each other
  • this affects safe driving decisions
It should be logged as a warranty infotainment defect, especially on a 2-month-old vehicle.
Summary​
  • This is a known MG HS Hybrid+ infotainment GPS fault
  • It is caused by vehicle GPS prioritisation + software
  • The fix is dealer calibration and firmware update
  • Wired projection may reduce symptoms but is not the root fix
Cheers
Hi
Have your phones updated to iOS 26 as I found out to day completely new display and working speed.
Cheers
Hi, past few days when I connected my Android to my MG4 ev, it gave a warning on my phone saying car does not pass security to play android auto as date was wrong in the car.
For about 4-5 days my car was displaying date as February 11 2026. Only yesterday it went back to cussing date and konissues connecting Android auto. Has anyone else experienced this?
Thank you in advance,
Reelika
When using android auto you can disable location permission for it. This would force it to use phones GPS. This solved the problem for me, although of course cars GPS is still useless.
how do you do that please?
I have a Moto G phone with android 15 so it can be a little different on yours, you need to google it.
On mine:
1. Open Settings
2. Then go to "Apps"
3. Open "See all 999 apps" - number is an example, not sure how many you have
4. There is a search button on this page so search for Android Auto
5. When inside Android Auto open "Permissions"
6. Click "Location"
7. Select "Don't allow"
This solved the problem for me.
Cheers
I picked up a new HS HYBRID+ on 19/01/2026 and also have issues with the Navigation system (Car Navigation, Apple Maps, Google Maps), It doesn't matter which I use I have the same issue. The GPS system sometimes doesn't accurately reflect the position of the car. It starts giving crazy directions because it thinks the car is 2 blocks away. This seems to happen a lot when you turn or change direction. It says things like "head towards Street A and then turn left into Street B". But I am already on Street B. So I am physically on Street B, (which is where the navigation system directed me) but the blue arrow indicator on the screen shows the position as somewhere else. It corrects itself after a while but makes the navigation system unusable because it is constantly giving incorrect instructions based on the inaccurate location of the car
