Hot spot wifi not working
Roberto 2761
Derby
MG4 (2022-2025)
Hi have just had my trophy long range into the dealers, weather not showing hotspot not working or wifi,
Picked up car dealer says it's all good no problem they tell me the car does not have a hotspot or wifi it uses your phone as data which is utter rubbish as the car has its own hotspot.
So they have had the car all day and done nothing and the problem still exists also can't log in to I smart, any ideas guys (help) as mg are no help
Do you get the "Initialization is failed" Error message when manually updating the weather info?
also, is your "user" app working (loading POIs for example)?
I couldn't get the weather app working on r59 and r63 and went back to r46, where it is working good.
other users still have a working weather app on these versions...
There's a well-reported workaround for the hot spot not working - set a manual DNS address in your mobile device. (e.g. 8.8.8.8 which is the Google DNS server, or 1.1.1.1 which is CloudFlare DNS).
siteguru
Dont think its an actual conection problem as my phone says it is connected to wifi but not available.
the wifi symbol on the front of my phone shows full bars with an exclamation mark.
Tim
I think that is exactly what I've described ... full signal but no Internet connection. And there's no Internet connection because everything tries to connect via names, but actual servers are found via numbers/IP addresses ... the DNS (Domain Name Server) is what translates names to numbers/addresses.
As a test, open the browser on your phone (whilst connected to the hotspot) and enter 142.250.65.195 as the website address ... this is the IP address of google.co.uk ... if the web page opens then this should confirm my theory.
My vehicle hotspot was working ok until update R59 , 10 mouths later I had update R63,the hotspot then worked for a few days , then it stopped working
MG have limited the amount of data to 1GB per month so you might have run out of this month's allowance.
    Votes: 1,099 77.7%
    Votes: 213 15.1%
    Votes: 103 7.3%
