Joe Boatman
Page 198 of the car user guide/manual shows how to place the car jack:
But there's no car jack in the car, nor is there anywhere in the polystyrene fitting where it should be fitted. The text in the manual tells me to:
There's a triangular pointer impressed into the painted sill but no domed recesses underneath. There are several oval slots with rubber grommets along each sill and when I removed one, the steel seems very thin to be able to support the car. In any case, the only car jacks that I have seen have a U shaped bracket, like the one in the above illustration - using such a jack would surely damage the sill.
Any advice?
I asked Halfords to rotate the tyres but they want £60, so I thought about DIY! The £60 does not include rearranging the TPMS valves so that they would match the diagram on the dash. (I haven't found how to pair each TPMS to the car, although I could remove each one after rotating the tyres and put them back in the right order. And then blow up the tyres again). Or, for £45 per wheel I could buy new TPMS's by sending the supplier the hex codes.
I know that KwikFit don't recommend rotating the tyres, neither does the manual which also shows how to swap wheels on p26:
Note that the
domed head of the jack must fit into the corresponding
recess in the sill plate (There is a triangle indicator in the
area shown by the arrowhead. See the illustration above).
Any advice?
