timothy
Can anyone give me some advice. I have dented the corner of the front bumper on the black plastic trim on my mg4
Plastic can be welded, shaped and filled like metal, just different processes used.
I had this repaired on another car:
I suspect many would leave minor damage and consider a repair only when it was time to sell the car.How much would that be likely to cost though? I wonder if it's worth it, given that the plastic is so soft it's likely to happen again and again.
This is my picture
In my case the damage affected the whole side of the car including front wing, door and rear quarter panel but the total cost of the repair came to less than £300 IIRC.
Front camera is not much better for judging low down distance, with its fisheye lens.One of the advantages of the trophy is the front camera but I agree that a front distance warning system would be very useful.
A bit of pressure from the back and gentle application of a heat gun should pop that out.This is my picture
I haven't looked but I'd guess the lower cover should come off.The only problem would be is getting behind it
Try Dent Devil. £130 to repair my minor dent in wing and repair scrape in plastic trim. Hairdryer works wonders on plastic.How much would that be likely to cost though? I wonder if it's worth it, given that the plastic is so soft it's likely to happen again and again.
