johnb80
- May 22, 2023
- Gainsborough, Lincolnshire
- MG5
I was keeping it simple (so I could understand it LOL)Just a note to add to @johnb80 post, the Victron capacities are in VA, not watts, so a 3000VA is around 2500watts with a correction factor of 1, like a toaster or other heater element type load, once you get into the other type loads, including anything with a capacitor, if not even going to attempt to come up with power efficiency factors.
Victron have really gone to town with the possible configurations. They all seem relatively easy and intuitive to configure and of course, there's a massive internet presence in forums etc with loads of experts ready to help.The Victron units can be paralleled to increase capacity, but better still, is a load activated stepped turn on that feeds a second inverter into the AC supply side of the primary inverter, then turned off when no longer required ..... all programmable, not smoke and mirrors, but that Arthur C Clarke coined term sometimes comes to mind![]()
I'm sure you will along with the MMI that Victron supply it would soon come back to you.Hopefully, if anyone wants to know, I can still remember how to do if asked .....
The EV batteries do have some disadvantages, cooling & heating, the format of them is not ideal both physically and electrically, the BMS is designed for the car integration whereas the BMS units meant for domestic supplies work as designed and communicate with the inverter(s).The last item, if @johnb80 is referring to the Tesla Powerwall ..... I'd think twice about using one, they are built with cells containing cobalt, so susceptible to thermal runaway fire risk, LFP, LTO and Na+ suffer no such risk, last more cycles in a house battery load situation, and the salvage EV comes with all the battery monitoring, safety battery enclosure and the MG LFP variants output 220vac 50 hz at up to 7kw (7,000w divided by 220v = 31.8 amps) so make sure you use 5 AWG multi-fine strand conductor, 2 core and earth orange flex lead, to carry the load from the EV to the house power entry .... your call as to adding a plug and wall socket to make it a plug in appliance if it makes all concerned feel happier about it![]()
