Is this car a good buy?
I had no doubt that the test would be conclusive and impressive.
You get used to the settings and gradually master them.
Yesterday I had the opportunity to drive my wife's diesel car home. The difference compared with the MG3 is quite simply impressive: the MG3's responsiveness and roadholding are very reassuring, not to mention the silence of the engine....
We are going to go for a bit of a run in it next week if only to make sure the petrol gage isn't stuck on full!!!.
Just purchased the zs trophy, can anyone explain if the equaliser can be adjusted on the radio, would like to adjust base, treble etc. Thanks.
I am trying to find out if the screen behind the wheel can be changed, I took a picture and noticed there is 5 dots on the right hand side of the screen mine is on the second dot and shows a number 2 in a square box, I assume this indicates there are 5 screen options or am I wrong.
Soz forgot to send piccy
Not sure about the ZS Hybrid, or even if this belongs in this thread, but is there a button on the steering wheel which has one square over layered on another. If there is, try pressing that and then press the toggle switch control to the right or left to see what options it scrools through. Probably the odometer, Tpm and battery etc.
Which thread should I be in then to be asking questions? But yes it does have the square over a square and I will try it later, thanks very much for your help.
Just start a new thread.
