Issues with Range/Power usage
bumrar
Burnham, UK
MG4 (2022-2025)
Hi,
Just got a second hand MG4 Trophy Long Range. Using it to commute to work but getting what seems to be dreadful range based on my reading of like posts on this forum.
Essentially its a 55min journey, roughly spit as A road (7 miles) B road (3 miles) and Motorway for 21 miles. the average speed over the whole journey is 35mph, doing about 75mph on the motorway. I'm getting 2.1 - 2.3mls/kwh over the whole journey.
At time of driving it was cold ~3-4 °C
I understand that the temperature and driving slower on the motorway would benefit usage, however I still feel like I would expect more range?
When we first bought our MG4, we weren't EV trained, just loved that performance the moment you stepped on the go pedal.
Then we learnt about changing to eco mode, watching the power meter on the right hand lower side of the drivers screen and realised that stab on the go pedal used a lot more battery than a lighter touch that still felt like it was going well, just not neck snapping ... but we still give it a bit every so often ;)
Sports mode eats battery like you aren't planning to drive very far.
25% is still 1/4 tank of fuel, so not the panic point, 5% is when the old petrol gauge red light came on .....
T1 Terry
Hi,
Seems normal for the time of year, guessing heating on and you are doing 75 mph on the motorway
@bumrar, All the previous responders have given thier experience of ev motoring, and I'd agree with them all. Keeping the efficiency up especially in cold weather is always a challenge. I did a journey similar to yours of motorway, A and B roads totaling 65 miles. My speed on the motorway was around 55mph. I also used the heated seats, and kept the HVAC on 22 degrees (no a/c).The journey worked out to an efficiency of 3.4mls/kWh.
I get that slowing down on the motorway helps efficiency but 55mph is a step to far for me😁
Well maybe a bit pedestrian, but it would save about 7kWh of consumed energy (about 1/3 less than at 75mph) and in reality only add 6 minutes to the total journey time of 55 mins.
Driving style has a lot to do with it too as @T1 Terry says with the impressive acceleration on tap it's easy to exploit it.
Who remembers the national speed limit in the US which was set at 55mph for years in the fuel crisis in the 70's to reduce consumption of the average American 5 litre V8 engine.
Driving slower certainly reduces consumption, but you also have to avoid being a rolling road block. The rate you accelerate from stationary up to speed and the rate you accelerate to change speed will save battery draw down.
On the long climb out of Adelaide, we use the cruise control to flip up 5kms at a time till we reach 90km/h (56mph) in the truck lane, because there is no way the trucks could do this, even empty, maybe bobtail, but there are 3 lanes so they could pass if they needed to ........ once we reach the top of all the big climb, we do the same 5km/h speed increase until we reach the 110km/h speed limit. Because there are a lot of up and down sections, the 100km/h i actually more fuel efficient than the 90km/h, momentum takes it further up the next hill before current changes for regen to load ..... any faster than 110km/h does eat into the battery capacity ..... and the wallet and the licence, speed cameras everywhere and Highway Patrol Police cars with radar guns ..... you fine out the level of pain within 2 weeks of the offence .....
T1 Terry
@T1 Terry, interesting that you use the cruise control, I've tended not to use mine so much and let the car slow down on uphill sections of motorways, while watching the power meter and driving the car on the accelerator to keep the power acceptable, of course on downhill sections hopefully you’ll be in regen. With cruise on the power just sky rockets to keep the speed constant uphill. and in eco mode the less than subtle switch from power to regen.
Yeah I used to think that just setting a low-ish cruising speed would be the best for efficiency but speaking to a few of the speakers at the everything electric event set me straight on that one.
The rule is you want to keep the power as close to zero as possible while generally working towards the desired speed.
Regen is great when going downhill if there is a car in front (or at the speed limit or if the hill is really really steep), but otherwise it is better to get the car to stick to 0% power and speed up a bit gathering some momentum for when the hill ends.
Similarly don't floor it to maintain speed going up a hill, accept a bit of speed loss as you go up and then you'll get some back.
I think that is how the "hypermilers" do it.
The problem in our case is, that is a 12 km hill and it must be climbed, 7.5kms in the first bit, the rest in the next bit, after that, they sort of balance out .... naturally, regen doesn't return the energy lost climbing the hill, but it helps ..... letting the car speed up above the 110km/h limit, not financially viable, that is where the mobile speed cameras and fix speed cameras are ..... at the bottom of the hill, or actually, just before you start the climb up the next hill .....
T1 Terry
My commute us almost identical to the OPs. I got my MG4 Trophy LR in Late November. So its been cold ever since I have owned it.
However I've driven EVs since 2021. Sooooo I run it in ECO and A regeneration setting. Keep to 65mph and try to drive as smoothly as possible, anticipation etc . So I rarely have to stop. Its how I drove my early 50kwh Mokka-e.
I'm getting between 3 and 3.2 which was less than I was hoping for. But hey its freekin' cold. The warmer weather is coming and it'll improve. I got my Mokka-e to 5.9 in the summer.
Such hypermiling is how I keep myself entertained on my commute. So I'm happy with it so far.
You have 61kWh of useable capacity, which translates to around 7 litres of diesel.
Obviously you're not going to go far with this.
WLTP is really super-misleading to people who don't know any better 😑
I can appreciate, folk trying to eke out every mile, by driving in eco, keeping to 60/65 mph, AC off, heating low, etc, etc. But sorry that's not for me. Personally didn't get an EV, to drive any differently.
It's a car, I drive it, as a car. Perhaps that's just me. And as always, each to their own. 🙂👍
    Votes: 1,080 77.8%
    Votes: 208 15.0%
    Votes: 101 7.3%
