DonLeslie
Whilst trying to silence the audible lane assist warning I seem to have switched off the front facing camera. The user manual (I have a ZS Exclusive 2021) isn't very helpful on restoring it. Any ideas?
Don
Don
I think it might be used to augment the 360 outside view, but I don't remember seeing a dedicated view for just the front.Well, I thought I had seen a forward view similar to the rear view. Or am I mistaken?
Not on the Exclusive.I get front view after using reverse you can also bring it up by pressing the 360 button and tap front of car same as side view just tap side of car
I agree that a good utilisation of the 5 camerasI wonder why it doesn’t double as a dash cam - that would be great.
The camera at the top of the windscreen would be better as a Dashcam since it is powered and works to feed camera signal to the lane assist and auto headlight systems so it would seem like a good idea to use these. However other than Sentry Mode on Tesla I don't know of any cars that do use it so I suspect that the lens systems and imaging chips are optimised for the systems they serve and therefore may not produce and useable video signal we ould find acceptable for DashCam footage.I wonder why it doesn’t double as a dash cam - that would be great.
FYI, the front camera is at the top of the windscreen, the square near the number plate is the forward facing radar.I can tell you a funny story about the front camera. Recently I had a fall and when I went to our
local medical centre to be patched up, I hit a bush with my front number plate and cracked the plastic surround. I later glued it up and used an old style large paper clip to hold it in place while it cured. A day or two later I got a warning that the cruise control following and pedestrian avoidance systems weren't working! As it happens I had left the big clip in place and the arms of the clip were blocking the view of the forward camera which is installed directly under and behind the number plate in my ZS. BTW I do NOT remember a forward view display, in fact I have a separate camera mounted on my dash and run off a USB port.
BTW does anyone know of a means of using regenerative braking under cruise control.
My area of NZ has a lot of 80 Km speed limits and the control is useful for this, does seem like
a waste of energy and wear on the brakes without regen though!!
My own car is 94% solar powered as I charge it from a 5 Kw solar roof and at 36 degrees South this
produces quite a lot of energy. I also power the house in daytime and export any surplus power back to the grid (about 300 kW/H last month) Southern summer of course.
