MG 4 long range battery
Golea9
Dundee
MG4 (2022-2025)
Hi. I have a MG4 long range, 64 kwh battery capacity. A few days ago I charged from 3% to 97%. The total kwh received was almost 55 kwh, is this normal or is the battery is not 64 kwh?
3% is about 2kWh & 97% is about 62 kWh. So 55 + 4kWh is 59kWh if you believe the values are mathematically accurate which they are not.
There is still battery capacity left when the car reads 0% & 100% is different if fast charged from a DC charger as balancing does not take place. Slow AC charging will balance the cells and can take half an hour or even longer if balancing has not been done for some time and can add a kW or 2 even after the software is reporting 100%.
The other complication is that of the 64kWh capacity only 61 kWh is useable.
So there is no definitive answer due to variable scenarios . The real answer is "It depends"
@Golea9
Welcome to the MGEV Community Forums!
No need to apologise for being a newbie!! We were all in that situation once.
I can't move your post and I don't think you can either. But I've tagged two of the Forum moderators who can move the whole thread.
This is from 2 years and just over 8,700 miles in my XPower. Using the battery % vs what the chargers say they have delivered has show a difference of 219 kW over 137 charging sessions (108 AC and 29 DC, with 22 to 100%). About a 7% variance.
From the battery % this is roughly what the useable kW should be in an XPower
Thanks for quick replies ! I'm trying to figure out why the battery drains so fast, with a full charge I get 120-130 miles when it's below 4 degrees and 200 mile on good weather even if I charge it slowly. I've had the car since it was new, I've always had the same range
Could speak a debate about the right way and wrong way to do it but do you do equalisation charges?
And check you intelligent battery heating isn't on, that uses a lot of power and some people had it defaulted to on
It's off intelligent battery, equalisation mean under 10 % and charge on slow? I did it....could be from charging port lights ? lights are off but charging normally
It is normal to get significantly less range in winter. It will be heavily influenced by how you drive, where you drive and the weather.
Biggest effects on range:
  • Temperature (cold battery has less range to give)
  • Speed (drive slower on the motorway makes a huge difference)
  • Hills (reduce range significantly)
  • Wind (can reduce range significantly if headwinds)
Unless that is all motorway driving though it's seems very low for a long range
@Alb @Rolfe
?Move this post to MG4 forum?
Hi , I'm new here! Can you move it for me , or I have to do it ? Thanks!
Just for information, if you see an action you think a moderator should take, the best thing to do is to report the post and make your suggestion in the report. We'll get to it and get back to you. Moving posts, merging threads, that sort of thing is fine to report. It doesn't have to be a suspected rule breach.
Do you drive with your Aircon/ heating switched on?
The car doesn't have a heat pump, so HVAC system uses a lot of energy. You said that in warm weather you get a decent range so I wouldn't worry about it.
You could try using seat heaters rather than AC, but that will cause problems when it comes to condensation.
200 miles in warm weather isn't a decent range for a long range and 12-130 in the cold is also crap, definitely some issue going on.
    Votes: 1,072 77.8%
    Votes: 207 15.0%
    Votes: 100 7.3%
