Just found some specs, looks very fast.
PERFORMANCE
Drive Train RWD AWD
Driving Range: NEDC Combined Cycle (km) *1 755 625
Driving Range: WLTP Combined Cycle (km) *1 655 575
Battery Capacity (kWh) 100 100
Battery Type NCM NCM
Acceleration Time (0-100kph, s) *1 4.6 2.74
Top Speed (kph) *1 220 240
Motor Maximum Power (kW) 300 200 + 372 (Front+Rear)
Motor Maximum Torque (Nm) 500 302 + 500
Bugger can't get it to format with all the data lining up. Looks fine in edit mode but reverts back to stupid once saved.
Edit moderator: My attempt using the "Insert Table" feature:
Drive Train | RWD | AWD |
Driving Range: NEDC Combined Cycle (km) *1 | 755 | 625 |
Driving Range: WLTP Combined Cycle (km) *1 | 655 | 575 |
Battery Capacity (kWh) | 100 | 100 |
Battery Type | NCM | NCM |
Acceleration Time (0-100kph, s) *1 | 4.6 | 2.74 |
Top Speed (kph) *1 | 220 | 240 |
Motor Maximum Power (kW) | 300 | 200 + 372 (Front+Rear) |
Motor Maximum Torque (Nm) | 500 | 302 + 500 |
Now with "code" feature:
Code:
Drive Train RWD AWD
Looks like the least awkward way would be to copy to clipboard from the original source, then paste into an editor like Notepad that uses fixed width characters, line everything up, then copy and paste into the forum editor between code tags.
