MG Marvel R EV Forum
RAA
Finland
Marvel R
MG Marvel R EV Forum:
MG Marvel R Performance 2022 Problem: the program drowns activated commands, e.g., opening the doors from the handle button, works when an on/off command is executed in the setup. The same issue occurs with automatic opening (without touching the keys), as well as with the driver's seat automatic memory/welcome: the seat does not always return to the last position even though it has been saved in memory.. the trunk foot opening does not work at all.
Sorry to hear about your problems.
I'm presuming you took it back to the dealers, what did they say? Or have you tried the old disconnect the battery for 10 minutes solution. Probably won't work, but might do, certainly with a try. 🙂👍
Welcome,
I can only say I stopped using foot boot open because it is a bit quirky and the seat memory you might not be using it as it should be, recheck owners manual ? Mine worked correctly once I understood how it was supposed to work
