stoilis
I fitted my MG ZS EV 2022 with a power tailgate. You can see videos here:
Some thoughts on the modification:
If you don't need it, it's probably not worth the hassle, but that's your decision.
- Open/close using physical buttons:
- Closing using fitted driver's seat button:
- Open/close using key:
- The usability could be improved. It requires a 2 step process for the opening. Press-hold-release, press-hold-release for going from closed to fully open position. And if you don't get the timing right, it may need an additional press-hold-release stage. It's not a problem, but it's kind of annoying.
- It came with a foot-sensor, but it opted to skip it.
- The kit was bought from AliExpress but right now I cannot find it. It seems to have been discontinued, but I believe it should turn up again. For what is worth, this is the seller.
- It was fitted by John Kleis Audio. Highly recommended, if you are looking for similar kind of work. Initially I thought I could install on my own, but it required more involvement than I am comfortable.
