SRMiller07
Hi, I'm just trying to work out if it's just me having some drop off in power availability with the gen 1 zs ev with this cold weather.
This morning (-5c) I set off on the school run with 50+ miles on the range and 4 bar showing on the battery. All seemed ok. Then I noticed after a mile or 2 that when accelerating it only peaked at 70% power. After dropping the first kid off I went on to drop the next off and the battery dropped to 3 bar and then I only had 60% power. After dropping the last kid off I cam home (around a 6 mile round trip) I noticed that the car would peak at 60% power and then drop to 50%. I got home and put the car on charge and it had 36% of the battery available!
I had this a week or so ago and found that if the first state of charge warning light came on I then had 40% peak power and would then drop off to 30% and the car could barely get to 50-55mph.
This time when I put it on charge I had 21% on the battery).
All this is happening on one trip and the car isn't being switched off in between. Just as the the charge drops off so does the power.
A bit worrying when I live in MK and need to pull out on to roads which are either 60/70mph in rush hour.
I get that cold weather can affect the battery but this seems more "pre-programmed" to happen at set states of charge and is linked to the external temp, rather than the actual temp of the battery, as I assume the battery would be a bit warmer towards the end of the journey?
My biggest grip is that there is now on screen warning to state that the power is being limited which would be very handy to know!
I do have the car booked in on 7th March to have this looked at and also to repair the drivers wing mirror which won't go back in when locked.
Just wanted to know if anyone else had something similar?
I believe the latest BMS is on the car from the last service (voltage dropped to 449 rather than the old 455?) and I can now charge on an AC without having to lock the car. Not sure if this has anything to do with it?
Thanks for any comments!
