mykd83
We recently bought a 20 plate ZS Exclusive, and having moved from an Outlander Phev to a full BEV we thought it was time to get a home charger installed. We picked the Easee One as it's very neat and we needed it to be small for where it was going, and set up the schedule on the charger to only work during the Octopus Go off-peak hours of 00:30-04:30. I know the 1st Gen ZS EV doesn't have charge timers, but I'd read that some updates allowed the chargers to wake up the car, and since both services had been done at the MG dealer I figured it would be up to date.
First time we tried to charge overnight, nothing happened. After some Googling, a Bluetooth OBD 2 adapter and an app to read the versions, it looked like the car was still on original software for most things (although has the outside temperature and range displayed, so seems to have had the Comfort 2 update). So we took it in to the dealer, tried to explain what was happening and what should happen with delayed charging, and they did an update and told us it should be fixed.
Checked the software versions again, and the only one that has changed is listed as DCDC in the app, which should be related to the on board charger. But the next time we tried to charge overnight, again nothing happened. So now I'm not sure if there are other updates that need doing, or if there is an issue with the Easee One charger and the MG (the Rolec chargers at Center Parcs on holiday had no problem with the delayed charge before any updates had been done!)
Does anyone on here have a first gen ZS EV and an Easee One charger? I'm hoping I can find some quick fix through Easee support or holding the dealer's hand as for what update to do, as they keep telling me everything is up to date
Edited to include the fact that it's a UK car - not sure if different regions have different software/firmware versions etc.
