Wychall
I had my new Ohme home charger installed today and now have a question for fellow Ohme-steaders. The charger is rated 32 Amps but is only charging at 27 Amps. The installer says it's because the settings need to be changed on the car. However, he couldn't say what settings as he wasn't au fait with MG's. Are there any settings on the car?
He also failed to install the earth rod that was quoted for. Might that affect the charge rate?
I've since found that there should be a local isolation switch to power cycle the charger in the event of an rcd trip. The only switch is hidden behind a built in fridge so it is definitely a sub-standard installation.
So what are your views on the low charge current?
