Radio volume while indicating
pete l
France
MG3 Hybrid+
Hi all,
While I'm listening to music, when stopped at a junction and the indicator is on, the volume drops to almost nothing. Can this be adjusted ?
Pete.
I assume this is because you have the safe turn feature switched on that brings up your 360 degree cameras on the central screen? If it is, when the cameras are on, press the settings icon on the smaller camera screen and turn off the safe turn (I can't remember the exact name they give it but it is obvious) and then your cameras won't come on every time you indicate at slow speed, and your volume won't dip.
On my MG5 PFL the radio (or music) volume drops when the indicators are is use because the indicator "sound" is created by and relayed through the Info System speakers. If the same occurs on the MG3 Hybrid+ I don't believe it can be changed.
No, we have a little speaker below and to the right of the steering column!
I can confirm that what johnbristol said is correct, the safe turn option cancels the camera and sound problem.
Shame, I would like the camera to stay on and not lower the sound :-(
Same here!! I wish you had the option sometimes to override some of these settings! I've turned the setting off as the lowered volume annoys me!
