Rapid chargers.
Hi everyone not sure if this is obvious but some of the ccs chargers are delivering 150 to 350 kw
So what is the maximum I should use if any ???
No maximum. The car will limit it. If you use a 350Kw it’ll still just deliver 80 max (and less most of the time dependent on battery temperature and charge level. )
Of course, if there’s a 100 and a 350 next to each other, use the 100 and leave the 350 for someone who can benefit from it, but that’s just etiquette rather than technical.
Also, you'll find the chargers with the higher output (i.e. 150 to 300) are going to be more expensive so you'll only charge as fast as the car's limit but still pay for using the fast charger despite not reaching the maximum speed!
Hope this helps
Cheers
Bloggsy
Yep good point buddy 72p kW going to be paying double bubble and then it could become rather expensive !!!!! 🤪🤪
