evets
Thailand
IM6
I along with four others, recently took a 160km road trip, not very far but data is useful. The battery went from 80% to 44%. That indicates an easy 320km range with comfortable head room. Obviously working from a 100% charge would shift the range by another 100km perhaps. The trip consisted of around 10% back country roads at about 70kph, and 90% four lane highway through flat paddy land at 100kph. The car says it consumed 17kWh/100km, and that’s a little bit higher than the 14.9-15.1 it gets running local errands. The lack of brake regen on the highway increases the kWh load. I’m pleased with both figures. The ‘Lane Keeping Assist’ and ACC functioned almost perfectly. Some highway curves make it slow down more than necessary. It navigates the curve just fine but overslows. A minor issue considering the entire car. I love it!
What version? Performance or standard (long Range in UK).
So in old money that's
99.5 mile trip
199 mile range +
Extra 62 miles to 100%
Pretty much a steady 62 mph journey
17 kWh/100km = 3.655125 mi/kWh
I would imagine in pretty warm weather flat roads with the Aircon going. (365 mile range)
I wonder what the drop to 70 mph will be?
99.5 mile trip
199 mile range +
This would seem to suggest a max range of around 260 miles which is poor. However, 3.6mi/kwh should give around 360 miles?
This would seem to suggest a max range of around 260 miles which is poor. However, 3.6m/kwh should give around 360 miles?
Yeah exactly what I was thinking, going by the figures posted they are different.
3.6mi/kWh seems more likely for the driving described
3.6m/kWh seems more likely for the driving described
Saw a post this morning on a FB page that said they 360 miles…...
Thank you for the write-up! I'm curious about this bit:
Do you mean that you had to brake harder than the regen was able to provide, so the physical brakes were used? Or do you mean that brake regen was set to minimum? Braking using the brake pedal will always use regen first, only switching to physical discs and pads if you ask for more braking force than the regen can provide.
This is why all "xxx regen setting is best for economy" arguments are simply myths.
I apologize for my lack of clarity on regen braking. Around town/city, one is frequently lifting off the throttle pedal, and that turns the momentum of the car into mechanical energy that drives the car’s motor(s), as opposed to being driven by the motor(s). This turns the motor(s) into a generator and that generated power goes back into the battery. Coasting recharges the battery and this process is visible on the driver’s front screen by scrolling through options with a sideways press of the right side scroll wheel on the steering wheel.
Obviously cruising on a highway doesn’t include much coasting, therefore not much regen braking. Then consider that the aerodynamic drag increases by the square of the speed, and the required power increases as the cube of the speed. That means a lot more power is consumed the faster you go.
Attached is a chart I generated with a Python script some of you may find interesting and/or useful.
No need to apologise and your explanation is very useful for those who aren't familiar with regen and how it benefits some situations more than others. I simply wanted to make sure that any new EV owners reading this thread didn't think that regen didn't apply in motorway driving at all, or that the IM5 is any different to any other EV in this situation.
BYD is the same. Regen when lifting the foot from the 'gas' pedal is laughable.
Breaking is what activates regen.
Chinese are not keen on single pedal driving. I believe they are moving towards a full ban in China.
Range of 250 miles sounds logical to me considering the size and weight of the car.
Not bothered actually. This is at least 3,5 hours driving in our motorways.
With it's charging speed a quick stop for a top up would be a welcome break for most of drivers.
I would definitely need the loo after driving for 2 hours, never mind more 😁
If the LR only offer around 250 miles of range I will cancel my order. I ordered the IM6 LR as I expected to get nearer 300 miles which would allow me to drive to Cornwall (a regular trip) without HAVING to stop at a charging station.
Yes the range seems very poor considering MG's official figures, I can get 250 out of my XPower (in summer).
Apologies I should have been more clear; my comment was about the launch version.
I can't see why the LR would not be able to deliver 300 miles; driving sensibly.
