Reverse Camera Display
James in Aus
Canberra, AUS
ZS EV
Hi Guys,
Sometimes when I turn the car on and quickly put it in reverse, the reverse camera on the main display appears as the image below. Most of the screen is taken up by the rear camera with only a small portion of the screen showing the 360 degree view. The part of the display that allow you to change camera views does not appear.
I personally like this larger view of the reverse camera but it only come up rarely. Is there a way to switch this view on or is it a glitch in the vehicle software that allow it to happen?
I wonder if you are able to click/touch the screen to do that. In home screen there's a 360 view button. It allows you to change view. I have the same make/model. Will try that to confirm soon.
On a separate note, I think the camera quality is sub par on MG ZS EV, not sure how much they saved by not going for slightly better resolution cameras.
I'm not sure if this will help but you have it setup for guidelines on the display, if you use the dynamic display it also shows where the car will move to when you steer.
They are yellow lines, with them switched on my display always shows in the full screen.
Rob
I drove an MG4 the other day which seems to have a much better camera than the ZS.
Hi Guys,
A glitch? on an MG? in the software? impossible :rolleyes: :rolleyes:
I am familiar with all the setting for the reverse camera. When you put the car into reverse, the display normally splits into three screens - 360 view, current view and change view.
The display in my original post only come up when you start the car and quickly put it into reverse before all the systems have booted up. It looks like a software glitch as I can't get that view normally.
Old tech cameras
