The AC forgets the set temperature (MG3 hybrid+ Trophy)
Pe3k
Slovakia
MG3 Hybrid+ Luxury
Hi everyone, I have a new MG3 Hybrid+ Trophy, and sometimes my air conditioning doesn't remember the set temperature after starting the car. After starting, instead of the numeric temperature, the screen shows "LO," and the air conditioning immediately starts blowing at maximum speed. I have to turn off "LO" and set my desired temperature of 22 degrees. It doesn't happen after every start, but about every 2-3 days. I usually have the air conditioning set to 22 degrees and on automatic mode. Has anyone else experienced this issue? Am I doing something wrong?
It happens to me too.
on average every week.
But you are still stopped and it is not difficult to modify.
The central vents can be closed: horizontal control towards the outside of the two.
It happened to me twice. Once after I was waiting in the car with the engine off and screen off. When I restarted the car the setting was LOW. Once when I used the remote iSmart to heat the car. Did not change the indicated temperature as it showed a goal of 24°C. When I 10 minutes later arrived at the car the heating was working at LOW setting. When I now use ismart I change the temperature control to any other setting then 24 and it works fine.
Does it perhaps go 'LO' when it first starts sometimes because it's unable to provide heat from the ICE at that time, until it heats up itself?
