Volume button starts radio- Normal?
MattyS
UK, Eastbourne
MG4 (2022-2025)
Hi all,
Recently I've noticed increasing the volume moving the right joystick up also starts the media be that radio or Spotify.
I was driving along and wanted to increase navigation volume on Google Maps but it turned on the radio instead.
As far as I'm concerned this is new behaviour, has anyone even experienced this? Possibly a loose connection?
I know pressing it in starts/stops the audio playing, but I've never tried raising/lowering volume to see if that does anything. I'll try to remember to test this when I use the car tonight.
I belive that raising the volume, raise the volume of the media currently playing. Ie navigation volume is only raised i navigation is currently speaking.
Having the default being radio seems ok. Also remember you do not have on/off button for the radio, only a mute button
Hi all,
I've done exactly as you did when wanting to alter the navigation volume. The navigation voice had finished just before I moved the joystick and the radio came on.
Yes but at the time there was no media playing, so the up button seems to act almost like a play button also.
If you look at the media display (or the top-left of the screen) you'll see the playback icon change between > and || rather than any type of mute symbol. 🤷‍♂️
In my Trophy left/right on the joystick switches on the radio and changes the channel (next up/down in the dab list). This usually happens when I forget I have switched the star function off and, in my case, try to change the HVAC fan speed.
This behaviour comes from permission system of the Android Subsystem --> In my case: I've installed Findroid (a Jellyfin fork) to watch movies while charging. If I try to increase volume via right joystick or plus and minus buttons while watching, the sound of movie stops and DAB radio app starts to play music. How to solve this bug? With force stopping the DAB radio app or Bluetooth music app in your case. Then increasing volume with hardware buttons works flawlessly.
Is there any way to force close the app without a modded system?
I tested this last night ... a tap up or down on the right stick starts the selected audio input playing. To be fair though, in my Vauxhall Vivaro bus that I use for my school transport job it is the same ... mute the radio then tap the volume up or down and it starts playing again. And I'm sure every other car I've had has done the same. So the MG4 isn't doing anything unique here. 🤷‍♂️
I think I found a "solution" without modding Android Subsystem: If you use a wired Apple Carplay or Android Auto connection, it claims the permission to change volume and you can adjust voice guidance volume in Google Map's settings then. There is a button to start a voice tts example and while it's playing you can adjust with + and -. This workaround has even worked with Newpipe (a YouTube Client), Jellyfin und Spotify as a native app install. My car is MY22 SW69 and I use the latest FICM software version R45. The radio app doesn't interfere.
Amazing thank you!!
    Votes: 1,080 77.8%
    Votes: 208 15.0%
    Votes: 101 7.3%
