JodyS21
- Jan 24, 2021
- Location
- Milton Keynes
- MG ZS EV
Like watching paint dry....I've recorded my car sitting on the driveway with the heater on full running the battery completely flat (I sped it up x8!)
The car was purchased after 15/1/2021 and has had all of the latest updates applied when I collected it.
At full charge and balance, it shows 449Volts (under no load 0Amps)
The GOM had turned to - - - when I started the test, voltage was showing 376 under load (15-20Amps).
@375Volts (under 15-20amp load) Message popped up "Low Charge. Aggressive Driving is Not Recommended"
@369Volts (under 15-20amp load) Message popped up "Air Conditioning is Limited by Low SOC"
@358Volts (under 15-20amp load) Message popped up "Power Limited. Limiting Speed" Tortoise Icon lights up.
@349Volts (would've been under 15-20amp load) Message popped up "HV Battery Shut Off" Battery crossed through Icon lights up.
Only thing now being used was the 12V battery.
After a minute or so of letting the battery "recover", on switching back on Voltage showed 367V (at 0Amps as off)
Plugged in AC granny charger. Charging: 0% SoC / --- mls / 17:00
Latest BMS (15/1):
Max Voltage 449V
Min Voltage 367V
Voltage range available 82Volts.
@Cocijo is doing the same for his car, with the Pre-October buggy BMS (455v).
We will see whether we have the same voltage range available (5 taken from the top and added to the bottom)
(Shame I haven't got OBD2 working yet so see what that showed)
Latest BMS (15/1):
Max Voltage 449V
Min Voltage 367V
