Walks with Enzo
Hello everyone.
We currently have a Vestel wallbox and Alpha ESS home battery (10kWh) and solar.
At peak performance the solar will generate just under 5kW, max output on the battery is 4.8kW.
I'm using solar to charge the MG today so wanted to try the wall box. Load was higher than the solar or battery was providing so rest was coming from the grid, so went back to the granny cable other wise I'd be using peak rate!
Do any of the wall boxes left you adjust the output, so I could charge at say 3kW instead? Will changing the current setting on the car change anything? Didn't seem to make a difference for me.
