AMT Secret to Smooth transmission
My engine is off but we can't make any change on the screen. Maybe i need an update or it's because i have a hs trophy petroleum.
mine is the same model, 2023-2024 made, they call it MG HS Luxury in Italy. but it is the UK trophy equivalent. Mine is also the petrol version. my menu is ok. may be you should bring your car to the dealer and ask for a software update.
btw, you have not taken the photo of the full screen. maybe there is something else on the far right corners.
To solve all of your problems regarding a complete lack of coordination between the transmission ICE and lag in EV mode.
Simply search AMT Mode for MG HS and follow the instructions to change the setting in Engineering mode in the infotainment system. It has worked for over 4000 owners who have messaged me directly since I first mentioned this on forums in January 2024.
John Smith has studied this along with a colleague since launch in 2019.
It solves everything regardless of PHEV / Automatic DCT and even Manual Transmission.
Here's the link to my original comment at the end of this post. Just read what a difference it made to Jto an established member of this forum.
Hi John, I have just bought a 2021 MG auto PHEV, can changing it to AMT as mentioned damage anything?
It's very important NOT to have the engine running when you are in the engineering mode! You are basically telling the ECU to do a mini remap and it will override your command if the engine is running or engaged.
All you need to do is follow the video. And yes go to page 8 and see what emissions setting you currently have enabled. ( Probably CN - 6 ) China 6 is factory setting strangely even though Euro 6 is available in the settings. And we are in Europe ... However you want to use EU-V (Euro 5 ) !!
You will instantly notice the completely superior driving experience.
Hi,
I made the change to AMT with the engine on! Have I made a cock up? Can I just have another go with the engine not running? My car is a manual gearbox MG HS Exclusive 2022. Should I only select MT when making the change?
Thx!
Hi, I am new to the mg family
I recently joined so I tried to do what you suggested, but I don’t have page 8 on my engineering mode, I change to mode 1 driving and AMT, what do you suggest… I am from UK and the car is an MG PHEv exclusive 2022
You will instantly notice the completely superior .
Changing to mode 1 and AMT changed the car completely. There are no hesitations in changing gears anymore. Thanks to whoever shared this!
I am a bit curious about what 'mode 2' does. Has anyone tried it?
Hello. The one thing AMT can't do is damage your vehicle.
As yet and reported by over 7,000 MG HS owners, ( Including 100+ Manual Gearbox Owners) there are NO DISADVANTAGES or unwanted SIDE EFFECTS to making the changes thus far. ( Remember this AMT mode was 1st discussed in 2019 and people around the world are still driving happily in that mode. No engine or transmission components are affected as these are basically software changes to the ECU that are put there by the manufacturer. Logic says that no components are being worked harder, and thus none should wear out quicker.*
I hope this answers your question.
Hi, late to the party! Have just purchased a 2021 HS phev and am having the lagging issue at 50mph in ev. Have tried switching to AMT using advice in thread above and it seemed to work initially 1st/2nd drive however seems to have returned to normal. Any advice greatly appreciated love the car apart from that!
Hi Andy. I'm afraid in 'ev only' mode you will have that hesitation at approx 50mph where it changes from 2nd to 3rd gear (I have found 4th gear for the electric motor, it is somewhere around the 70mph mark by the way). It is a pain in the bum but something we have to live with, it's caused me an issue more than once I must say (caught gearbox in 2 minds when over taking a lorry after having to slow down).
Easing off as it is about to change gear (indicated on power gauge) can ease the gear change, slightly less noticeable and quicker to settle, booting it makes it like a stroppy child and seems to prolong the gear change and the agony.
I would love a fix but that is only possible by buying the latest version.....
if you don't have the battery full, if you set the car to charge the battery with the ICE, you don't have the lag anymore. the lag problem is caused by the car's logic that forces the electric motor rpms going too high before changing the gear. if you set the car in "recharging mode" the logic changes and you don't have the lag anymore. I always switch the mode if I expect to have the need to overrun someone at the speed that causes the problem. you can switch back just pressing the EV button.
