Coulomb
Moderator
- Apr 24, 2021
- Solutions
- 1
- Location
- Brisbane, Australia
- MG4 Trophy ER
We've had our MG ZS EV for almost a week, and I've had trouble locking the car just outside our local pharmacy. Tonight, my wife rang to say that the car would not unlock for her. She later added that she had trouble locking it, but eventually it co-operated. She was parked in pretty much the same parking spot that I was when I had trouble locking it.
I drove the other EV over, bringing along button cells and my toolbox, and having read up on how to use the mechanical key. The mechanical key got us in (eventually, but not after sounding the horn because the alarm went off), and it was not a trivial operation.
My guess now is that there is some sort of microwave band transmitter nearby that is interfering with the key fob. Maybe it's something to do with the shopping centre's wireless systems, or something to do with the pharmacy.
After much fiddling with the fob, boot, both door handles, eventually the car became unresponsive. I suspect it thought there was an intruder, and just ignored us from a certain point. Well and good if there really is a break-in, but frustrating if the fob is playing up.
Anyone else had that problem? I guess we just don't park there and walk a little further.
I thought I'd document how to use the mechanical key, as I found the manual a little hard to follow (a few more diagrams would really help). My apologies if this is done to death already.
You press the "button" (that some have complained is pressed too easily) at the red arrow to open the fob (arm moves left per the green arrow). You remove the mechanical key (or retrieve it from the floor, it falls out easily) per the blue arrow. Fold out the little tab at right angles (orange arrow); you'll need this to get enough grip.
On the driver's side door (only), you'll find that there is a small hole under the cover at the end of the door handle: can see the square hole by my thumb below:
Prise something into that hole to pop off the cover; you will probably need to be pulling the door handle to get it to come off. This exposes the mechanical key slot, shown in red above. You use the mechanical key, and the lever goes up to open it (I think; someone at the carpark helped us at that point while I was going for some pliers). Opening the door without the fob seems to trigger the alarm, so get inside as soon as possible and place the key fob in front of the cup holders (I think that's the right area), and get the car to ready to prevent or to turn off the alarm.
An adventure of sorts for we retirees, but I can imagine it not being so much fun if you are under time pressure, with bad weather, not having suitable tools and/or patience.
