Hot Red 5
Just did a small modification to my MG5 as I had an incident with a locked charge cable in town the other day and had to remove the cover to get at the cable release.
see photos below. I just tied a bit of nylon cord to the release pull and threaded it through the windscreen washer refill hole. I have locked it down under the bonnet arm just in case it decides to pop back under the cover. I did check it and it does work ?
hope this helps.
hope this helps.
