Dangerous Adaptive cruise control
Joningy
Hampshire
MGS5
My 3 week old MGS5 has developed a significant and potentially dangerous problem with the ACC, it doesn't always turn off when pressing the the centre of the 3 left side steering wheel buttons, (the button showing a steering wheel pic)
To set ACC, I'm pressing the left centre steering wheel button, followed by pressing the left steering wheel toggle button to set the speed.
To turn off I press the central of the 3 buttons, or brake pedal.
BUT pressing the centre button on the left side steering wheel doesn't always disengage the cruise control, it keeps going at the set speed, although the screen shows it turned off, ie the light changes from blue to white (I think it's green to white!) {the light is actually blue not green when ACC is activated}
If approaching a junction at perhaps 40 to 60 mph it can be very scary, especially if there is a car in front of me as it keeps trucking on at the previously set speed.
It does eventually turn off, but taking several seconds and not instantly as it should do and sometimes does, it only seems to be a problem over around 30 to 35 mph, below this speed it works as intended (so far)
I contacted the main dealer's service department, I received an unsatisfactory response from them like "we haven't seen many of them yet" NO offer to look into it.
To reiterate, it stops instantly by pressing the brake pedal!
Has anyone else experienced it?
Can anyone explain if I'm not carrying out the correct procedure (can't see this, but it's a new car, my MG4 never gave me a problem)
I normally just tap the footbrake but if your buttons are not working as they should get it in to the dealer.
Hi there @5teep , yes I'll pop in on Monday, we are at the dentist 200 yards away from the Main Penton dealership in Salisbury, it was lunchtime when I rang on Friday, a girl answered the phone and went off to ask someone, they sell Citroen (spit) as well so my guess is, they cover for each other I'll see the main guy at the service desk tomorrow. cheers!
Do you see the same behaviour in speed limit mode as well as ACC mode? This will help to indicate if it is a button issue or a software issue.
Almost certainly a software issue @Anon70 , the button actually deactivates the ACC, well it turns the light from blue (updated colour from green to blue) to white on the driver display, but it takes perhaps 5 or more seconds to switch off, that's way too long for many people to actually deactivate, as I've mentioned braking works as it should, maybe it'll give the dealer a few scratching heads, I'll keep the thread updated as I'm sure it could cause a nasty situation in the wrong hands!
Maybe just a fatory reset will fix it, but MG should know about it.
I don't think it's a button issue because selection works 100% of the time. It's only deselection that has an intermittent glitch.
UPDATE - I visited the main dealer in Penton MG Salisbury yesterday, they were very helpful, neither the sales manager nor the service manager had heard of the ACC problem in mine and @Alb 's MGS5, the car is booked in for an examination next week (21st Oct)
I cannot believe @Alb and me are the only ones with this problem, so I'd suggest other S5 users should try disengaging the ACC by using the button instead of just the brake pedal, but sometimes the button works so it needs doing several times on a journey to check the glitch.
I use 1 pedal driving and wondered if this might be causing the abnormality, but turning it off made no difference.
Further update to follow when I have the results.
UPDATE 2
Wasted half a day yesterday, after dropping off the MGS5 at the MG main dealer, picked up about 2pm, NO CHANGE, the intermittent ACC fault still there.
Unable to talk to the service manager, I was told "I think they've updated a camera"
Will call today, but I think I'll try shouting a bit louder at MG head office, if I can find an email address.
I can cope the same with it as @Alb says by using the brake, but it could cause an accident if someone doesn't react quickly.
UPDATE 2
Shout as much as you like at MG UK head office they have a hearing impairment and dont hear/listen.
An mg4 owner contacted them about a fault, after getting no joy at the dealer, and got a reply saying don't contact us contact the dealer we just sell them the cars.
UPDATE 2
MG's customer service email address is [email protected] include the name and address of your dealer and the registration number of your car.
Unlike @LenEV2016 experience when I contacted them about the amount of time it was taking to sort out the charging problem with my MG4 they contacted my dealer authorising the part replacement almost immediately. Mind you I did accuse them of micro-managing the dealers.
Personally, I'd always use the brake tap to disengage the ACC.
I have found slight variation with the way the ACC controls work on my new S5 compared with the MG4.
But....brake pedal tap to disengage, and then press the button later to turn the system off is working for me.
I'll see if the button acts as a disengager switch later today. Must confess I always regarded it as a system on/off button, rather than a disengage switch.
Thanks @Ian Key, I'll pop an email to them, not sure I'm going to get a satisfactory, or helpful response, but it's something they should attend to as a matter of safety, as my local MG dealer looked at the owners manual yesterday, which definitely states the steering wheel button is on & off, out in the S5 today, the delay in turning off can vary from instant off to well over 5 seconds. @Loveclose
You'll need to do it several times @Loveclose , I found it turns off using the button if it's not on for long, but leave it a minute or two and then often, but not always, the delay occurs.
I emailed MG Customer service today using the email from @Ian Key, (thanks Ian) regarding the potentially dangerous Adaptive cruise control, I still don't know what if anything my local MG dealership did on the recent investigatory visit.
MG's reply was as expected, but I'll wait for their response, if it materialises.
Their reply:-
"Good morning,
Thank you for contacting MG Customer Support regarding your enquiry.
We have received your enquiry and will review the information provided. A member of the team will be in touch with you in due course."
MGS5 ACC & auto dipping headlights update.​
A bit of a surprise to me this evening, waiting until after dark to test the headlights on my new S5, which was into the MG garage to investigate the adaptive cruise control as mentioned above, but returned to me exactly the same, no ACC improvement, but the headlight anomaly has been unexpectedly sorted.
They are now operating the same as the MG4, much better, but not perfect!
Apparently some sort of updated front camera module, they either replaced or more likely did a software update, hoping it would sort out the ACC, but the unexpected happened, it sorted the auto dipping headlights! I was told the same camera does both things.
MG will apparently contact me in the next week or so and probably instruct Salisbury Penton MG on the next steps, which I'm pretty sure is a software glitch.
Not expecting anything rapid to happen.
Anyway if by chance you use the shitty S5 auto dipping headlights, there's a mod available!
Well I did try the ACC switch yesterday....when ACC is engaged, the first button press disengages ACC....then have the option to 'resume', or press the switch a second time to switch the system off.
If your ACC button doesn't disengage the system,and the switch it off, then it's faulty and needs attention, IMHO!!
But I'd still use the brake to disengage. I don't often think about switching it off!!
ANOTHER UPDATE on adaptive cruise control not always switching off with the steering wheel switch.
Nearly 3 weeks has passed and apart from an automated response to my original email, I've had NO "real person" response from MG Consumer Services, That is in my opinion POOR, a simple acknowledgement to say they are trying to sort out the bug would have been enough to keep me quiet, but NOTHING at all, despite Penton MG saying I "should hear from somebody, it normally takes about a week"
I have threatened with rejecting the car under the Consumer Rights Act 2015 if nothing is done quickly, I copied the email to Penton MG sales, but like head office, I've had no acknowledgement whatsoever as yet.
TBH, it's wearing a bit thin, I can cope with the problem by braking, but the fact is that the "off" part of the on/off steering wheel button is not working correctly and not fit for purpose, even after a trip to MG Penton's service department who were unable to fix it.
I guess they are overwhelmed with MGS5 smaller problems, it's not been the best new car experience I've had.
My previous MG4 was faultless from start to finish, incidentally it's scheduled to be returned to Santander this afternoon.
The S5 is great in so many respects, I guess somebody has to be MG's guinea pig.
I just wish to F*** they'd get their ass's in gear and rectify the niggles they are encountering, or at least talk to me.
You only have to look at the MG 4 threads to realise how bad they are at rectifying stuff, there is a reason they came bottom of the barrel for reliability and aftersales (in the what car survey)
Mine has twice braked for no reason on motorway with adaptive cruise on ,nearly shit my pants very scary
That has happened to me several times and very likely lots of others, not on a motorway, on ordinary A & B roads, it obviously sees something which appears dangerous, but its a false alarm.
I'm becoming rather scathing about MG, My S5 is lovely to drive, excellent value so long as you don't pay full retail cost, but it has a few glitches which MG doesn't seem to want to know about and certainly their customer service is diabolical.
