Dashboard noise
Fred4009
Montpellier
MG4 Trophy LR
Hello, I realized that behind the foam of the dashboard in the upper part when it is cold there is a slight crackling / noise of plastic, have you ever noticed that? and how did you solve this problem?
There are some threads on this. Use the search function and you should find them. :)
Make sure the noise is not coming from the rear view mirror. My garage wanted to rip out the dash to investigate! After reading this forum I removed the mirror and greased it with silicone grease. Problem solved.
Common problem on both Gen1 & Gen2 of the ZS EV.
Yes there is a cure to the cracking / creaking noise.
Here go :-
