Driver display MGS5 Trophy clearing past trips mileage etc
mgaz
Lancashire
MGS5
Hi, can't seem to get the since recharge, since start, accumulated mileage, on drivers Speedo screen does not seem to be on drivers screen despite trying all steering wheel buttons, really wanted to reset it all as it's also on main (left)display of car too
Also it states over 14000 kilometres on those screens, when car mileage is only 1500 miles( I know that can never be adjusted)
Any help appreciated being trying a while.
Thanks.
You need to select the ones to show on the main screen, select the car icon and it is the second tab possibly status but my memory is shattered after a hard week at work.
The button to use is the screen button to scroll though the different “cards” (middle right side) looks like a large and small window
The images on the main screen are there to allow you to select which ones you want on the driver screen.
Thank you Gus and Alb, will try and sort it in a bit but, any idea why those screens show 14000 Kms I think, when car has only done 1500 miles?? Thanks
Thanks in the hope it helps someone else in the future, still trying to get one of these like "since charge" to go on steering wheel card menu slot. Will keep trying....
Grateful thanks, my problem is getting the 'since charge" window from the main screen on the left to the drivers display(Speedo screen)
on the right
so I can then scroll through the cards and it would be able to scroll to the since charge
with the diagram you have kindly posted.
Thanks
on the right
Thanks
On the main screen, press the car icon at the bottom and select cluster.
What you see here are just examples and allows you to add or remove things that you can scroll through on the cluster (drivers screen).
Make sure “from last charge” is ticked.
Then on the drivers screen you can move between the ticked screens by pressing this button on the steering wheel.
Mine only very rarely shows the Navigation and Multimedia panels, they are selected on the main screen and I know you have to have the cars Navigation and Media active. They have shown up a couple of times in a few hundred miles of driving, but 98% of the time they only display that they have no information.
