Driver infomation
Jeff
Norwich
I have just changed my mg z's ev for the MG5 ev,in the handbook it shows that you can view an image of the cars driving and regeneration by accessing via the buttons on the right side of the steering wheel, all I can access is lumination of back light to the display or set maximum speed limits.is this correct.
Use up and down on the right set of buttons to switch between the different info screens. Pressing right takes you to the options you have found. Left should take you back out if I remember correctly.
It should be available using the up/down on the right hand side of the steering wheel itself. I'm interested in getting where you are.
