Drivers door window controls not working.
Hi
I have the same problem in my 2023 MG ZS EV LongRange. The windows don't work if I control them with the switch in the driver's door, and the mirrors don't open or close. Does the 2023 ZS also have a problem with the wiring harness in the doors?
Is the part number of the driver's door switch the same in the version with and without the cameras in the mirrors? Because the error message is “No response from the driver's door switch”.
What do you advise - to replace the harness or the switch?
I have a technical question - when replacing the window driver's switch with a used one from another car, do I need to reprogram something in it, or should it just work as in cars from years ago?
Do you need to buy a clean/new switch that the car will program into its network and BCM - what do you think?
DTC shown by the diagnostic program is U0215
I’ve got the same problem. Just bought a 21 reg MG5 and the window controls and wing mirrors are affected. Can’t open or close the windows from the drivers side, nor will the wing mirrors open or retract. Asking the dealership to resolve this ASAP and sounds as if it’s this same known problem.
