Gearbox breather seal
Bobby95
The Netherlands
ZS EV
Hi all,
I own a MG ZS EV mk1 from end 2019 and still enjoy it very much. Recently I had a problem with the reduction gearbox (strange sounds) and is was replaced under warranty. When inspecting the new gearbox I removed the cap of the breather hose on the gearbox and saw that it still has plastic seal over it.
I emailed to dealer to ask if it needs to be removed (seems logical since it needs to breathe) but they told me it doesn’t need to be removed.
Since I don’t fully trust their expertise to be honest i’m curious if you guys can tell me if it indeed has to be removed or if it can stay on.
Welcome to the forum.
I think that the breather is essentially a pressure relief valve, and the plastic "seal" is part of that valve.
This part was discussed in the below thread.
Upvote 0
Thanks for your reply @Coulomb!
I have indeed read the thread before publishing this one. Nobody seemed to have removed the cap. To me it doesn’t make sense that the seal should stay on since it, like you also said needs to relief the pressure.
Upvote 0
My guess is that the "seal" usually holds the oily air in, but somehow moves such that excess air pressure is relieved when necessary. In other words, I don't think that the valve would work with that plastic part removed. It looks to me like it's designed to pop outwards under pressure, and will reset once the pressure reduces below a threshold.
Upvote 0
Hmm that sounds logical to me indeed.. I don’t see how it could open and close again though. It is was also already full of air and under pressure after driving when pressing the white “seal”. You can feel that there is air underneath it.
Upvote 0
why worry, if anything goes wrong, back to the garage to fix it if they messed it up. I would not do anything myself that could invalidate warranty.
Upvote 0
After some digging i found out it is a Gore pressure relief valve. The white “seal” is a breathing membrane.
Hi all,
After some digging i found out it is a Gore pressure relief valve. The white “seal” is a breathing membrane and indeed needs to stay on.
Upvote 0
