Help needed: How to set a charging limit on MG ZS EV 2023 (Long Range)?
Den
4119
ZS EV
"Hi everyone! I’m an MG ZS EV 2023 owner based in Australia.
I recently bought this car used, and I have a question regarding the charging options. To maintain battery health, I’ve heard it’s best to keep the charge at around 80% for daily use, unless I’m planning a long trip.
I did some research and found that I should be able to set a charging limit, but I’m having trouble getting it to work. Here’s what I’ve tried so far:
  1. Via the In-car Touchscreen: I tried to toggle the modes in the charging menu, but the screen doesn't respond to my touch.
  2. Via the MG iSmart App: I checked the app settings, but I could only find the "Scheduled Charging" option; there was no slider or toggle for the charging limit.
  3. While Charging: I tried adjusting the settings while the cable was plugged in.
  4. While Not Charging: I also tried it while the car was unplugged and in 'READY' mode.
None of these worked for me. Does anyone know how I can successfully limit the charge to 80%? Is there a specific step I might be missing, or could this be a software version issue? [I also had a software update at the service center about 3 months ago, so I assume I'm on a relatively recent firmware.]
Any advice would be greatly appreciated. Thanks in advance!"
If you drag the left side of the top blue line to the right, it should slide to maximum charge to a higher to 90 or 100%
The schedule allows you to set the time of day that you charge the car, we have 5kw of solar so if I schedule to charge during daylight hours, it should charge from the solar. This also means that it will take longer to charge so I have turned it off.
View attachment 44366View attachment 44368View attachment 44367
View attachment 44369View attachment 44370
In iSmart App, Charging page, gear wheel top right. Totally not intuitive that it isn't in the Schedule Charging page.
