- Jun 13, 2022
- Location
- Paignton, UK
- MG4 Trophy LR
Hi, this came up in another discussion and may help people who are bit confused about all this talk about killer-wots and owwww-ers. The experienced will already know it.
Energy is measured in Joules (J). Power is measured in Joules-per-second (J/s), which is also known as Watts (W), a thousands watts is 1 kilowatt (kW).
If you run a 1kW appliance for an hour you'll be using 1 kilo-watt-hour (kWh) of energy, or 1000 J/s * 3600s = 3,600,000J.
Hence, with electric cars, the power of a charger is rated in kW and the capacity of the car is rated in kWh. A 50kW charger fully charging an empty 50kWh battery will take 1 hour (assuming no losses / slow downs). 50 kWh / 50kW = 1hr.
Range is simply capacity (energy stored, e.g. kWh) multiplied by distance-efficiency (distance per unit energy, e.g. miles-per-kWh or m/kWh), for example in the UK: 50kWh * 3.5 m/kWh = 175 miles.
However, efficiency can be measured in another way: kilo-watt-hours-per-100-km: kWh/100km. How many kWh does it take to drive 100km? Less is better. This is energy-efficiency-per-unit-distance.
So, on the continent, you calculate range by dividing battery energy capacity (kWh) by energy-efficiency and then multiplying by 100: (kWh / (kWh / 100km)) * 100, the kWh units cancel leaving the estimated range in km. For example, 50kWh / (15kWh / 100km) = 3.3 * 100 = 330km.
There are then more complicated usages that can get very confusing. Another way of rating charger speed is "how many miles of range will I get per hour of charging?", which is expressed as miles-per-hour, or mph (but not to be confused with speed, which is also measured in mph).
You can work out the miles-per-hour (charge rate) by taking the power of the charger and multiplying by the average distance-efficiency of your vehicle: kW * (m/kWh), which leaves you m/h or mph charge rate. For example, 50kW * 3.5 m / kWh = 175mph charge rate.
Hopefully this clears up any confusion.
