Jan was rubbish month for solar
Everest
UK
Not an MG
Looks like we were 20% down on solar generation in Jan 2026 compared to last year :( 🌧️🌂 Only made just over quarter of mega-watt hours this month, not much better than December - whereas Jan 2025 was over 320kWh.
Was it equally bad in other parts of the UK?
A paltry 74.50 kWh for us in Oxfordshire.
However, looking at reports from Givenergy (if these are reliable, which I'm wondering about) we got:
  • 57.06 kWh in 2025
  • 141.39 kWh in 2024
I wonder if January has been particularly wet and mild.
Our heat pump has been getting great efficiency, though I don't have any comparison to other years.
Hard to know if we are in other parts of the UK since we don't know where you are, apart from in the UK :)
I seem to recall a comment about Norfolk, but it would be useful to have had it in the thread.
Nigel "EV Puzzle" will do his update with January stats from Norfolk at some point which will be a much more detailed point of comparison.
Yep - we're in East Anglia. Interesting that we're 20% down, yet @GaryMG4 & @JohnV6 were down 5% and 10% for same part of the country - guess its also down to amount of real sun vs. bright cloudiness combined with panel angles etc. Fingers crossed for the rest of the year🤞
Our 11 y/o 4 kW array faces 240 degrees (WSW ish) and around 30 degrees angle so do much better with afternoon sun so I guess it just depends how the day develops. Last winter Dec-Jan generated 51+90, this winter it was 87+87, hoping for a decent spring again.
Here, in southern Lincolnshire, figures are:
January 2025: 107.40 kWh
January 2026: 81.40 kWh
So a noticeable drop here also.
Speaking from South Wales we have had a disappointing past 6-8 weeks with 2 anomalies.
First was Christmas Day. By far the brightest & sunniest of the whole month of December! And which is just 3 to 4 days after the shortest (ie-darkest) day of the year ! Was bitterly cold and windy outside though.
Then the first 6 days of January’26 were equally sunny/cloudless so was expecting a bumper solar January! But from the 6th onwards it has been depressingly grey,dark & rainy with just the odd half day of sun here and there.
That just sums up the UK weather. Unpredictable and very changeable.
12% down on solar generation compared to last January. And February has been sh**e so far!!
  • 57.06 kWh in 2025
I think Givenergy caution somewhere that their figures are not totally accurate due to the way they collect their info from the inverter (?) - but can't remember where I saw it! Certainly. I've found they don't agree with either Octopus or MyEnergi (which do tend to be closer to each other); but GE is all that is available to me for PV generation stats.
We've had the same Jan here, with a fairly small 5.5kWh solar array and 9.5kWh battery, but with our usage (inc. two low mileage EVs) still managed a tiny amount of export in Jan after domestic use.
Gen: -46%; Exp: -36%. But Dec 24 : 25 were almost identical (but never more than 5% export!)
The Myenergy app seems to correlate with my generation meter but then it uses the Harvi that came with the Zappi. As I'm on deemed export I don't take a lot of notice of amount exported unless I'm trying to get as much free solar into my car.
2025: 139.99 kwh
2026: 153.38 kwh
According to GivEnergy. I don't believe a bloody word of it. This is 2026.
The house was empty from 5th January. It was just ticking over, fridge, freezer, wifi, central heating at 10 degrees. There is no way there was nearly 20 kwh generated on the 8th, and if there had been it certainly wouldn't have been consumed by the house. Ditto these other suspiciously high days with impossible house consumption. It's a complete nonsense.
2025: 139.99 kwh
2026: 153.38 kwh
I've certinly had equally annoying info at times. Looking at your graph, there are (unlikely?) clear total blanks - vis. 9 and 12 Jan, as well as anomalies in pattern - i.e. why does the usually constant solar to grid pattern disappear for days on end from 6 Jan?
When I had something similar, I found that there had been some odd entries on the inverter notifications page, indicating (in my case) meter communications failures. It carried on for several days and eventually cleared. Their usually very helpful support engineer could only say it was very strange, but nothing he suggested sorted it out in the meantime.
What does the Power Graph show? With mine I noted that this showed daft ups and downs suggesting that everything was going in impossible directions at impossible times. Hasn't happened again since last October though - thankfully!
PS Different end of the country, but the comparative reading (house occupied throughout) from our small 5.5kWh PV array + 9.5kWh battery running an ASHP is:
I've had smart meter issues for some time and estimated bills, they did add an ariel to the meter due to poor comunications (I have still been Paid for feed in so must be getting some information?)
I was told the Smart meter will get a software update at some point
The following information is from the Solarman smart app..
Jan 24 164.04 kwh feed in 38.76 kwh charging 57.1 kwh
Jan 25 139.22 kwh feed in 11.84 kwh charging 74.08 kwh additional battery added
Jan 26 136.98 kwh feed in 5.22 kwh charging 76.02 kwh
in the south east.
He's definitely trying to catch as much sun as possible with all the panels he has. ☀️
(y) one definitely needs that amount of panels to generate much in this weather - looks like he got the same as we did for Jan :) But, if he thought Jan was bad, just wait for his next report. It's nearly half-way through Feb and we've only just hit 100kWh :( 🌧️
