AdamMGEV
- Feb 15, 2021
- Location
- Cheshire
- MG4 Trophy LR
So on youtube I just learnt that when you press your foot on the brake it is similar to having KERS3 on... it will regen your battery when you press the brake. I didn't think it did. So you could technically drive around in KERS1 and if you could use your brake efficiently it would regent the same amount as using KERS3?
Anyone know about this? I thought if you used the brake it was wasted energy... but if you roll along in KERS1, see what the regen is in current, then press the brake, it will regen more for those seconds.
I have an MG5 btw if that makes a difference, not sure if the ZS is different.
