Lane assist don’t interfere
sonybgt100
Greece
ZS Hybrid+
I discovered that the lane assist system doesn’t function properly. In clear conditions with very visible lines, it sometimes works correctly, but other times it doesn’t even activate. I’m concerned about this issue.
Please try it at your car also.
With these lines.
So it's between dashed markers. And you are sure the system wasn't in warning mode only (as you claimed it did not 'interfere')?
Does it correct if you cross solid markers? Btw, I have no access andvthe facebook link says no longer available.
I uploaded the video needs admin approval.
It works in these lines but not always some times yes sometimes no.
It depends on the mood of the system
Window is clean so camera can work? Does the the sign in the dashboard show it is in the right mode when it does not function?
Hi Sony. I use this feature extensively and have not encountered the issues you describe (other than when the lines are faded/not there).
As others have said, the cameras and sensors need to be clean. It also may be obvious, but you must have cruise control engaged and the MG Pilot switched on at the highest level for the lane assist to function.
Is CC really needed? I will get a ZS again next Saturday so I will check. (replacement car to have the mg4 fixed).
Mine doesn't always work either, i can cross white lines and get nothing, no beep, no tug of the steering wheel, then the next day, same road, it works.
In general, the lines are IMO blue if the system recognizes them, and then it will steer quite reliably; AS in other cars the system has naturally limitations, and low sun, wet surfaces, worn markings etc. will interfere with the system. The tug on the steering wheel will occasionally also happen without a blue line, like the car recognizes you cross something, but the line was not clear enough for lane centering to work; IMO the MG system works fine for what it is, I have had systems that work a lot less reliable in more expensive cars (I'd say esp. teh lane centering/following is above what you get at this price usually, and the adaptive cruise less jerky, and a Mercedes EQE rental constantly would loose the lines and telll me to take care myself e.g.), having driven a full FSD Tesla Y Juniper in California recently there is ofcourse a long way to the top though.
But in the MG, if it doesn't recognise the white lines, the steering wheel icon on the dashboard goes from white to grey. Mine is white when it sometimes does nothing.
At least, I think that's correct
Yes, mine is the same. Sometimes too effective when not required, and other times no response.
