Do you mean a set of locking wheel nuts? The ZS comes without locking wheel nu
I speak from personal experience when I say it is not nice to wake up one morning to find your new car jacked up and left on four bricks and the wheels have been taken !.They hide the wheel nuts under plastic covers, which means if you have to remove the wheel you have to remove the five plastic covers before you can get to the actual wheel nuts, to be honest with these alloys it's probably all the deterrent you needadmittedly I put locking wheel nuts on, MG original part ones for half the price on eBay
You can’t stop the “Pond Life” - but it helps slow them down at least.Hi.
I always put locking wheel nuts on just for peace of mind but you can now get devices off eBay that can bypass most locking wheel nuts, the only good thing about the alloys are they are distinctive to the MG ZS EV I believe so would look conspicuous on any other car.
I always remove mine prior to visiting either the dealer or the tyre shop.Have to be honest, have always disliked them. Depending on the design they can be a proper sod to use, especially if your local tyre monkey used the gun to tighten the nuts (since your average tyre technician doesn't have a clue what a torque wrench is). I've removed them from any car I've ever had that had them fitted.
I have a camera which alerts me with an alarm, if someone goes near either my MG or the wifes Spider, I would then go out and ask if anyone would like to play baseball as I have the bat, this would no doudt work. If that did not work I'd sent the wife out (she can be very scary, in rollers, face mask and hair net).I always remove mine prior to visiting either the dealer or the tyre shop.
Nut runners will absolutely knacker them up for sure.
It’s like a lot of things unfortunately, when they are installed and removed correctly, they are fine.
Each to their own I guess.
The MG is the first car I have owned in a LONG time that came with alloy wheels, that where NOT already supplied with locking bolts already fitted from the factory.
The ZS EV is fitted with diamond cut alloys, which can NOT be cheap to replace.
Thirty quid is a small price to pay for some type of protection.
Better than nothing that’s for sure.
Wheel & tyre replacement is either likely to be expensive or a sizeable claim against your car insurance.
Could well be the best thirty quid you every spent if you are unlucky enough to get a visit from the local “Pond Life”.
Once bitten, twice shy is the expression commonly used today I think.
Don’t be a victim like we where.
I was lucky, at least they did leave it up on bricks and did not dropped it to the ground.
Just give that a bit of though for a few seconds first.
You pay your money and take your chances.
The bloody cheeky "Pond Life" would probably nick your camera as well if they could get £20 for it.I have a camera which alerts me with an alarm, if someone goes near either my MG or the wifes Spider, I would then go out and ask if anyone would like to play baseball as I have the bat, this would no doudt work. If that did not work I'd sent the wife out (she can be very scary, in rollers, face mask and hair net).
Hi Terry - Yes you can !.I have a set of locking nuts from ebay. Can you just loosen remove & replace with locknut without jacking up car etc????
Kind regards
Terry Bailey
Good shout !.Generally good practice to make sure the security bolt is the first one you take off, and the last one you torque up.
Just remove a single wheel bolt from each wheel and switch out for the locking wheel bolt.
I would be a good idea to apply a little copper grease to the threads of the new bolts when installing them.
A bit of any lub is better than none, but a thin film of copper grease is perfect !.
They need to be tight of course, but you don’t need to go “Cave Man” crazy on them.
Oh ...... Don’t be tempted use a impact wrench or a nut runner on them !.
Start them by hand with the locking wheel nut socket, then final tighten with your wheel brace.
There is a torque setting, but just apply a bit of good old common sense !.
Don’t forget to hide the locking wheel nut key some where in the car.
Don’t keep it in the house for gods sake !.
Oh ...... Keep the 4 bolts you remove in a safe place also !.
Another “Top Tip” if you need pay a visit to the tyre shop, don’t let them attack them with a nut runner !.
Hi LovemyevHi Terry - Yes you can !.
Your very welcome @terrybailey .Hi Lovemyev
Thanks for reply
Kind Regards
Terry Bailey
