MG Canbus Protocol
Dragonfly
York
I'm trying to connect to my MG HS PHEV with an AutoPi, but at the moment I'm not having much look. Does anyone know what the required canbus protocol is?
On my ZS EV, I use OBD2/Elm command atsp6, which I believe means 11 bit 500 kbps, if that helps any.
You probably need to select the right ECU to talk to first. The Elm command for that is atsh, but I don't know what that translates to in a bare metal CAN bus message.
