MGS5 Accessories- what’s worth a look?
Do you know if they fit well? They have a boot liner too.
Fitted ones seem to be expensive, probably because they are heavy so cost a lot to ship from China.
Found these:
https://www.ebay.co.uk/itm/116637521940
I was going to have a look today, they call it a boot mat but if you zoom in it's a rubber boot liner rather than a carpet type.
I'm guessing it's a thin one as it shows it being cut with scissors rather than a knife.
my current one is a thick one from Ebay/amazon about 10 years ago.
Does it need to be thick? I suppose it depends what you are transporting. I was thinking of getting some hefty bags in case I need to move anything like that. Could even keep one under the floor.
If anyone was looking at the car trim removal kit, they are quite thick at the tips, 3-4mm.
If you're looking for slim tips to open up some finer parts, these aren't for you.
Have you been installing a dashcam or something?
So what have you chosen to pimp up your MGS5?
I will kick off with a set of MGTitan rubber maps front back and boot.
I will be looking for metal scuff plates for door entry points and one for the boot so the labrador doesn't ruin the paintwork. When I can find where to get ones that fit the MGS5.
Keep an eye on ES5 the model in China, most things are the same although they get a bigger screen in China and not the blooming stupid keys (no I am not a fan of the teardrop shape keys).
No, I get nominated for fixing my daughters and son in laws cars when things go wrong.
I've took a few interior panels off on my time
No need to remove trim to install cables for dash-cam, there's a power outlet on side of rear view mirror housing, Brilliant.
It's a great idea, the only thing is if you want parking mode it only runs while the car is on. In a lot of cars you can remove the plastic cover over the front camera housing and get to permanent 12V and accessory power, but I'd be worried about moving the camera and de-calibrating it.
Also if you want a rear one you need to run a cable back there. Still, a very good idea if all you need is a front one while driving.
Here’s the Alloy sports pedals. Bit of a fiddle to fit but look nice once fitted. Also got the correct size screen protectors from MG Titan. arrived in uk from china in 3 days, then with Yodel for 12 days to deliver.
Just for reference, I ordered roof bars from MGTitan on 17/7/25 and they were delivered in the UK today, 29/7/25.
I've seen some tailored mats on eBay for about £33, for 700gm ones. You can get the 400gm ones for less but they seem awfully thin.
I had an add on grille cover to change the looks, and also blackened out the logos.
Got these from China via Taobao.
here are the links, got the TPE floor mats recently too, and they fit well, except for the passenger side which does not have the hook to secure it down but there's the holes there - comes with the boot mat too but that's made for the top later only, and doesn't work well it you move the cover down for the bigger boot.
Floor mat - https://e.tb.cn/h.hrieRipwOJfKVu6?tk=Twwj4iUpUzh
Black badge - https://e.tb.cn/h.hJvsMYKZXO0oy34?tk=bnhs4iUqAp5
Grille - https://e.tb.cn/h.hri5jhpCYX2oz1b?tk=L0ZB4iUssrs
Right now, I'm just waiting to see if anyone has taken out the cover for the trunk and see if we can get a frunk in there.
